problem starting car ( no cranking) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2004, 01:55 PM   #1 (permalink)
View steph97's Photo Gallery
hey everyone, I have a problem with my car, the car won't start or crank what soever. I changd the starter, I have a new battery.
The only things I can tell you is that both the ECI IGN fuse (15 A) blew and the Starter Fuse (5 A) blew, both located inside the dash. anyone have any advice on what the problem can be!!!!!
Thank you
whoflungdung
steph97 is offline   Reply With Quote
Old 12-20-2004, 02:17 PM   #2 (permalink)
View toysarefun's Photo Gallery
Sounds like a direct short, check visible wiring for frayed or bare wires. Also retest your battery or try a different one. When does the fuses blow?, after connecting battery, or turning on the ignition?, or when in the cranking position? Replace old fuses with the EXACT same kind or you'll wind up with expensive fried parts.
toysarefun is offline   Reply With Quote
Old 12-20-2004, 04:01 PM   #3 (permalink)
the battery is brand new and all the fuses have been replaced as well as the starter, any other advice
whoflungdung
Old 12-20-2004, 09:41 PM   #4 (permalink)
View karugs's Photo Gallery
When the fuses have been replaced together with the starter and the battery, did they blow again?
If so then something is shorting them out.
karugs is offline   Reply With Quote
Old 12-21-2004, 01:15 AM   #5 (permalink)
Gameroom cash: $133300
View profuse007's Photo Gallery
to check to see if ur NSS (neutral safety switch) is out: turn ur key to ON
at the starter, theres a blk 10guage wire (smaller wire), jump this wire to the battery to see if it turn over and start. if turn over, ur NSS is messing up.
if NSS is messed up, try move the shift-stick back&forth and try starting again.
2009 Camry SE || Techstream V.6.0 with Openport 2.0 || TSX 4300K Denso
Houston-TX: need key chip, remote, or body features programming? PM me.
profuse007 is offline   Reply With Quote
Old 12-21-2004, 10:58 AM   #6 (permalink)
when the new fuses where placed there, they did not short again. And it is not the NSS I tried that already, thanks for your help though
whoflungdung
Old 12-21-2004, 01:56 PM   #7 (permalink)
about the new starter: Has the starter actually worked.., did this problem crop up immediately after replacing starter and battery, or was life hunky dory for awhile after the repairs. I'm betting your new/rebuilt starter is toast.
Old 12-21-2004, 03:15 PM   #8 (permalink)
Gameroom cash: $304355
Check the new starter for bad contacts. To do this, have someone hold the key in the start position while you tap the starter with a hammer. If the starter then turns, the contacts inside the starter are bad. This is a common Toyota problem and it can happen even with a rebuilt starter. If that is your problem, do a search for starter contacts. This is an easy DIY fix.
Mike
Old 12-21-2004, 04:24 PM   #9 (permalink)
no, problem occurred before I got the rebuilt starter. I hope that the starter isn't the problem again, but I doubt it!!!!!
whoflungdung
Old 12-21-2004, 07:51 PM   #10 (permalink)
Since the fuses don't blow anymore after the new parts have been installed then they damaged something that is now not working properly. Just trying to point out a few things you could miss out on. This needs more specific help, which I cannot give. Goodluck
Old 12-21-2004, 08:48 PM   #11 (permalink)
you obviously didnt try my method.
if you didnt try the starter thingy i said ur starter is either mess up or the 4 guage wire 12volt (+)constant is not plug in. its simple as that.
