Alloy metal rims lug nuts interchange ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2004, 02:26 PM   #1 (permalink)
View Canoe2's Photo Gallery
Question Alloy metal rims lug nuts interchange ?
I have 2003 OEM alloy rims with lug nuts. Can I use those lug nuts for metal rims ?
Canoe2 is offline   Reply With Quote
Old 12-20-2004, 03:12 PM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
if they have a washer no, if they look like acorns, yes.
terrastrife is offline   Reply With Quote
Old 12-20-2004, 06:53 PM   #3 (permalink)
They have washers. Toyota did not provide any lug nuts for spare tire, since spare tire has metal rim ?
Old 12-20-2004, 07:17 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
It depends on the wheel/rim.
Look at the wheel where the lugnuts sit against. It'll either be a flat hole or tapered hole.
Flat hole = shank style lugnut.
Tapered hole = acorn style lugnut.
"Skoolin' the unlearned!"
Old 12-20-2004, 07:59 PM   #5 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
does this have anything to do with hubcentric vs lugcentric rims?
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 12-21-2004, 11:16 AM   #6 (permalink)
Thanks for all inputs.
My steel rim is hubcentric, and I think it's tapered hole. I called Toyota dealership, they would not recommend for OEM Alloy lugnuts on steel rims. Probably I will buy lugnuts (0.75-$1/each) for my winter tires.
Old 12-17-2008, 04:56 AM   #7 (permalink)
View human01's Photo Gallery
Hi,
Take look at the wheel,i think toyota did not provide any lug nuts for spare tire.Get the tire to fit for that rim,may be flat hole or tapered hole.
mining xrf
human01 is offline   Reply With Quote
Old 12-18-2008, 01:01 AM   #8 (permalink)
Gameroom cash: $927300
iTrader Score: 13 reviews
View ASG14's Photo Gallery
^ Dude, this thread is from 2004........
5 Lug Corolla WHAT?
