heatshield rattling under car - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-20-2004, 07:53 PM   #1 (permalink)
93 toyota camry 4 cyl.
View daddyiamtx's Photo Gallery
Angry heatshield rattling under car
i plan to remove the shield thats near the catlic converter soon does anybody know the best way to remove this
daddyiamtx is offline   Reply With Quote
Old 12-20-2004, 08:30 PM   #2 (permalink)
tC
View 95camguy's Photo Gallery
i definetly would not remove it permanetly. toyota put it there for a reason. however if you plan on putting it back on you will want to spray the bolts with penetrating oil the night before(WHILE THE EXHAUST IS COLD, PENETRATING OIL IS FLAMMABLE). this probably should be fairly easy since your from texas where rust is less of a problem.
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline   Reply With Quote
Old 12-20-2004, 08:36 PM   #3 (permalink)
is this easy to get to once i raise the car i have a 93 camry
Old 12-20-2004, 09:18 PM   #4 (permalink)
Diablo
View GaviN's Photo Gallery
My heating shield used to drive me crazy !! Then I got rear ended, and now, I dont even hear it anymore......problem solved..
93 Camry LE & 05 Altima SER-6sp
GaviN is offline   Reply With Quote
Old 12-20-2004, 09:37 PM   #5 (permalink)
View karugs's Photo Gallery
So the solution is to get rear ended? Cool
karugs is offline   Reply With Quote
Old 12-20-2004, 09:38 PM   #6 (permalink)
Diablo
^^^Worked for me
Old 12-20-2004, 09:40 PM   #7 (permalink)
The Other White Meat
terrastrife's Avatar
why dont you just tighten the bolts?
terrastrife is offline   Reply With Quote
