Emergency Flasher not working
My emergency flasher is not working.Yestarday I tried to replace my front marker light bulbs(3157) with LED 3157 light bulbs. I turnd on the light and everything went out okay. but when I turned teh signal lights on, teh marker lights turned off.I then pressed the emergency light switch. Emergency flasher did not work. My head lights and tail lights are fine.
i checked teh fuse box under the steering column. I found that Fuse#35(7.5 A)was blown out.I repleced teh blown out fise with a 10 A fuse. My turn signal lights are now working but the emergency flasher is not working.
Do you guys have any idea why the emergency flasher is not working????????
