Can't get cover off 3rd brake light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2004, 03:43 PM   #1 (permalink)
View rohrerski's Photo Gallery
Unhappy Can't get cover off 3rd brake light
I need to replace the 3rd brake light on my 95 camry, but can't get the plastic cover off. I tried prying under it with a screwdriver, but no luck. Any ideas or do you know the secret to get it to pop off? The owner's manual makes it look so easy, but it's far from that. The technician at Walmart couldn't get it off either.
rohrerski is offline   Reply With Quote
Old 12-28-2004, 04:13 PM   #2 (permalink)
Gen5.5 Sportivo V6
terrynham's Avatar
View terrynham's Photo Gallery
it should be pretty easy to take off....
anyway, hold the cover with two hands and push it backwards (towards the back of the car). Hopefully that should unhook the clips holding the cover on, then you should be able to lift it up
~ Terry
terrynham is offline   Reply With Quote
Old 12-28-2004, 04:50 PM   #3 (permalink)
Torque Applicator
Bluesabre's Avatar
View Bluesabre's Photo Gallery
Have you looked under that 3rd brake light from the trunk? Not sure about your generation, but on 4th gen Camry's you remove the cover by squeezing the plastic mount clips from the trunk.
1998 Camry LE
5SFE
If you're not livin' life on the edge, you're taking up too much space. (stolen)
Bluesabre is offline   Reply With Quote
Old 12-28-2004, 05:13 PM   #4 (permalink)
Gameroom cash: $304355
Bluesabre is correct. I have both a generation 3 and a generation 4 Camry and I have found it best on both cars to go from inside the trunk and loosen the clips from there. It then comes off easy.
By the way, the replacement bulb is a 921.
Mike
Old 12-28-2004, 08:26 PM   #5 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
It's a pain in the but in a gen2. There are these flimsy plastic clips that hold on the cover. I brake one every time I remove that damn cover
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 12-28-2004, 10:29 PM   #6 (permalink)
View l0n3xstar's Photo Gallery
once you do it, its simple. i juss pull it up and then pull back and it comes off.
l0n3xstar is offline   Reply With Quote
Old 12-29-2004, 03:47 PM   #7 (permalink)
Pulling Out
View S2B_Blown_3.5's Photo Gallery
Well, I pry it off with a screwdriver. There are 2 good spots, about 3/4 inch from each side. Just stick the screwdriver about 2 inches in and pry it up. Usually takes about 5 seconds.
S2B_Blown_3.5 is offline   Reply With Quote
Old 12-29-2004, 03:50 PM   #8 (permalink)
Smile
Terrynham is correct. Just pushed the cover back toward the window before lifting up and out and it came right off. Thanks for all the help!
