Both headlights wont turn on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2004, 06:37 AM   #1 (permalink)
FloridaPino
eviltwin67's Avatar
View eviltwin67's Photo Gallery
Both of my headlights on my 96 didn't come on last night. I was just wondering if both lights would stay off if only one bulb was out. I find it strange that both bulbs would burn out at exactly the same time. I already checked both fuses and they are both good.
96 V6
Amsoil foam filter
Upgraded headlight Harness w/ Sylvania Cool Blue
APS 996A Remote Start Alarm
eviltwin67 is offline   Reply With Quote
Old 12-29-2004, 07:13 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
nope one can blow out and the other will stay good. check the relays (search the site for where they are if you dont know) and then the switch. i hate to hear your problem because i have a 96 too ......
^ and leaving it that way!
Old 12-29-2004, 07:32 AM   #3 (permalink)
Sold out for a Max
TheMajesticking's Avatar
View TheMajesticking's Photo Gallery
Did the other one cut out or completely blow?
Sounds like a relay or touching wires.
-Chris
TheMajesticking is offline   Reply With Quote
Old 12-29-2004, 07:33 AM   #4 (permalink)
View anuthaCamry's Photo Gallery
it's entirely possible that both can burn out at the same time, it's a strange world.
try the 2.0 fusible link, the 40 amp fuse, the integration relay, the headlight relay
the coil on the headlight relay has two terminals, one is +12 at all times and the other one is connected to ground via the integration relay when the light switch is on.
download the schematic
anuthaCamry is offline   Reply With Quote
Old 12-29-2004, 07:40 AM   #5 (permalink)
View karugs's Photo Gallery
Without knowing what happened previously, I'd check the fuses, relays, and perhaps the switch. I believe the fuses protect only one headlight, so if one fuse blows the other headlight should still be on. Hence, check the switch too. Or maybe it's just the grounding.
But before you do that, check if the bulbs are burnt and/or if the filament is broken. If it is then it's the bulb. If not then it's something else.
karugs is offline   Reply With Quote
Old 12-29-2004, 02:23 PM   #6 (permalink)
FloridaPino
eviltwin67's Avatar
Thanks for the replies. I'ts not the bulbs. I tried each of them in the high beam socket and both work, so it is definately wiring related. I guess I will find my meter and start checking the wiring.
96 V6
Amsoil foam filter
Old 12-29-2004, 03:06 PM   #7 (permalink)
Sold out for a Max
I see in your siggy that u upgraded the harnesses. Good possibility that this is where your problem lies.
-Chris
