differential/ auto tran fluid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-29-2004, 06:47 PM   #1 (permalink)
asscarracer's Avatar
View asscarracer's Photo Gallery
I was looking at a repair record on my car and it said, the differential fluid needed to be changed, would it infact mean that the automatic transmission fluid needed to be changed or are they different. This car is a 1993 Camry I4 Auto. Sorry about the long post, but I have another question about the rotors on my car, last week when I would brake, it felt like they were warped and this week, no pulsing, could it be possible that the warped rotors leveled out?
Thanks in advance,
John
asscarracer is offline   Reply With Quote
Old 12-29-2004, 07:06 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
The fluid for the transmission and differential is seperate.
They both use the same type (Dexron II/III ATF) of fluid though.
Doubt it. Once their warped, they'll stay warped. Only way to fix it is resurfacing the rotors (if their not badly warped) or replacing the rotor(s).
If you have a micrometer you can measure the thickness of the rotor at several spots.
You can also check them using a metal ruler and feeler gauges.
"Skoolin' the unlearned!"
Old 12-29-2004, 07:10 PM   #3 (permalink)
View anuthaCamry's Photo Gallery
i have the same car, you will need to lift and level the car and drain this using a 10mm allen wrench, or allen socket. the fluid is not shared.
anuthaCamry is offline   Reply With Quote
Old 12-30-2004, 01:16 AM   #4 (permalink)
ok, thanks for the help
1993 Camry LE w/ 104xxx mi
Python Remote Start/Entry, Low-Beam Silverstars, Ceramic Pads, Double Tipped Platinum Plugs
