If it really is your tubes make sure its clear. Some have shot compressed air up there to clear blockage. The tube plugs into a drain rail there, it may have worked loose but I doubt it.
I had a leak that was driving me crazy. Some said it was leaking from rear window sill. First I thought it was the exhaust vent in left side of trunk first, then the spoiler, then I thought it was poor fit on the trunk. It would only leak when highway speeds were reached.
Finally figured out that the water was coming in under the seals. Took the seals off, filled them with silicon and I am gold.
