Wanta Turbo my 3SGE Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2005, 07:25 AM   #1 (permalink)
View The Fonz's Photo Gallery
Australia Wanta Turbo my 3SGE Camry
G'day.
I'm in the middle of nutting out the way to turbo my 3sge camry, I have had experiance with twin turbo 1JZGTE's and 2J's, but this is the first time i have tried to turbo an N/A car
Firstly I should tell you that this car is my 2nd car and I use it for running around, It's to be as much as an engineering project for me as much as getting better performance out of this car, I'm not looking to make this a 9sec drag car, I would like a mild increase in power.
I have a 3sgte exhuast manifold, I have a VERY good tco6 mitsubshi turbo, and a ct26 I have ain't crash hot, either way it will be one of them, making an adaptor is no problem, I am not at this stage going to run an intercooler ( maybe later) I'm thinkin of running the oil feed line out of the oil pressure switch ( tee it off) and them once the oil goes thru the turbo I'm looking at running it back thru the dipstick making a y piece at the bottom of it. I would like to run around 5-6 psi, and I will be using a 2.5 inch exhuast system, I'm not sure on the fuel side of things yet either.
Has anyone done this, or since I'm new to this forum is there a thread on it.
Thanks in Advance
Regards
Dave
The Fonz is offline   Reply With Quote
Old 01-01-2005, 08:05 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
yes countless .... search ...
http://www.toyotanation.com/forum/t40029.html
there are many many more search around and just about every question would be answerd
^ and leaving it that way!
Old 01-01-2005, 08:58 AM   #3 (permalink)
Apoligies people,
I made a mistake, the engine is a 3sfe, NOT the 3sge
Thanks, I'll search away
Regards
Dave
Old 01-01-2005, 09:37 AM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
drop a 3sgte in.. therye cheap... like 2 grand if you look around. actaully what gen you got? the aussie authorties wont care if you drop in a 3sgte or turbo your 3sfe its the same to them
terrastrife is offline   Reply With Quote
Old 01-01-2005, 05:21 PM   #5 (permalink)
Fooly Sik RE!!!
View Wibbit's Photo Gallery
just for aftermarket performance parts i wouldnt look past a 3s-gte. Wraith has the engine in his car so you can talk to him if you wanna explore that avenue
1996 5 speed Vienta V6 Touring
|Rays Engineering|TRD|Unichip|BMC|Magnaflow|Whiteline|BR IDE|Endless|
My Vienta Website
Wibbit is offline   Reply With Quote
