unusual uneven tire wear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-01-2005, 04:20 PM   #1 (permalink)
View mikey13oi's Photo Gallery
this is a 96 camry. it was slightly hit in the front driver side. now theres wear on the inner and outside of the tire. the middle treads seem to be alot thicker then the inner and outer sides of the tire treads. anybody have any clue what it could be? pictures can be obtain if needed but its easy to make a mental picture of the tire.
mikey13oi is offline   Reply With Quote
Old 01-01-2005, 04:29 PM   #2 (permalink)
View automatic's Photo Gallery
Sounds like low tire presure, usually a small alignment adjustment is to be expected when you have a small accident, but that would effect both tires.
Unless it wasn't a small accident(?)
automatic is offline   Reply With Quote
Old 01-01-2005, 04:32 PM   #3 (permalink)
well...it was slammed into the side bridge wall at around i want to say 50mph. only the front driver's side was touched tho. could it be anything to do with suspension or frame? it was driveable after the accident...wasn't that bad. the rim was messed up bad.
Old 01-01-2005, 05:09 PM   #4 (permalink)
Auto-Cross Addict
SmokingTires's Avatar
View SmokingTires's Photo Gallery
If you hit, it will throw the whole suspension off. So both sides qould get messed up. An alignment should cure that.
However the wear does sound like low tire pressure.
'88 Toyota MR2 N/A - Sold
'99 Miata Sport - Sold
'85 Corolla GT-S - Sold
'02 MR2 Spyder - C-Stock car
SmokingTires is offline   Reply With Quote
Old 01-02-2005, 05:04 AM   #5 (permalink)
The Other White Meat
terrastrife's Avatar
if it was only wearing on one side then that woudlve been alignment.. both outer edges sounds like low pressure (another person saying teh same thing) i have the 15" wheels and drive 40psi front and 37psi rear. if youre saying thats too much on the front, id rather stay driving on the tread, not the sidewalls
terrastrife is offline   Reply With Quote
Old 01-02-2005, 05:07 AM   #6 (permalink)
Auto-Cross Addict
Your car makes me wet in the pants
