Originally Posted by jsandek
Having searched this site and seen that my oil leak (97 camry v6, 80,000 miles) somewhere in the vicinity of the front of the engine is not uncommon, I thought I would ask those in the know what the possibilities are before I arrange for repair at the dealer. I noticed it recently when I was changing to snow tires---oil on the front right A arm and the front sub frame giving about a drop of oil on the floor every other day or so. The bottom of what I think is the power steering pump is wet but I think it is being sprayed from CV boot (wet as well) rather than coming from this pump. The oil filter is dry. Some posts mentioned a distributor O ring but I cannot find a distributor on this vehicle. Also maybe a valve cover but I cannot vissually inspect myself. What else is being driven by the accessory belt that could be spraying oil? The oil pump? Could it be from the differential? The oil seems too light weight for this. The dealer suggested last year at the 60K service that I should have the timing belt done-which I deferred. Perhaps I'll have it done now slightly early while this is being looked into.
Thanks in advance!
i would guess on the power steering pump leaking as well,
camry v6 engine starting 94 may no longer use distributor for spark plug,
were you able to identify the color and smell of the oil?
