There is a hose that comes off the air intake tube and goes to somepart on the rear of the manifold. What is it? And is it neccessary?
My intake tube is starting to crack and needs replacing. I have some 5" flexi pipe that I can use, but i'm not too keen on cutting a hole and putting a fitting on it.
Thankyou.
__________________ 1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
When your throttle plate snaps shut, obviously air has no way of entering the engine.
Air bypasses the throttlebody and goes in the upper intake from that hose. Which, actually has an electronic gaget that acts like another throttle body, and controls the idle mixture and what not. Which is the IAC valve.
"The lamest twice banned, non-female member of-all time." -Ekam, Thanks, I <3 you too! AIM/Yahoo Toysrme257th
for anything, anytime; including camry turbos Now with Turbo!
It can. You can test the resistance to check it's function, and if you're not afraid of spilling the fuel that routes to it you can take it out and clean it too.
It will be black caked with exhaust, and gold colored from the oil/fuel baked on it when it should be silver. Like this:
That is the cold start injector on a 3vz-fe v6, but that is for demonstration purposes only. LoL!
Start a thread for your idle problem and we'll help you with it!
if you block it then obiously as stated b4 the engine cant breathe if ya throttle isnt open.. so like.. its kinda required...
But seriously, the only experiance I have with those motors is the '93 corolla I had years back, and it always ran like a jewel. Even after being totaled.
No need to apologize. At least I pointed them to a possible culprit. That's the dealer's job to fix their own car.
EDIT: I actually read about it too once but it was a different make so I figured it might not be the same. But seeing that it could be, I linked the two posts in hopes that something can be done.
