Are you wanting to perminantly check vacuum, or just right now? If you want a quick check, or just curious you can literally use any rubber hose that plugs directly onto the upper air intake, the PCV or brake booster lines if it's a big connection.
There are 3 or 4 lines on the throttle body that can be checked also, but they are used to swithc things (ie 0 vacuum at until 3000rpm, full vacuum until 300rpm ect)
"The lamest twice banned, non-female member of-all time." -Ekam, Thanks, I <3 you too! AIM/Yahoo Toysrme257th
for anything, anytime; including camry turbos Now with Turbo!
Yeah this is for a vacuum guage for inside the car. As you can sortof see, it's connected to one of the manifold hoses thats runs from the side of it. Just wanted to know of any other places it could possibly go for a more accurate response or not to diminish the cars performance in any way.
__________________ 1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
So long as you don't use one of the TB one's used for activating vacuums tuff you'll be OK.
Any hose or opening sucking air into the engine is a vacuum point.
That breather hose can be used to measure vacuum.
mmm the problem is, I have no idea which one to cut is easist and most trouble free as I heard if the sealing isn't good and theres a leak, its performance wise
Go to your local auto parts store and get a T connector for whatever size you want along with enough vacuum line to run to your gauge. BTW, What do yall want a vacuum gauge for? Just sometihng to look pretty?
Anyways...that point your circled is the breather hose. I wouldn't use that. You get oil vapour thru there and it may clog your guage over time.
Find a manifold vacuum point. Where i circled is this point on my 2VZ.
Looking at your picture, this is a 3VZ?? I'm not too familiar with orientation or specifc locations, perhaps someone can shed some light.
^ no. Our distributor is in the same location yours is. Right hand intake camshaft. The intake hose itself is also nearly the same.
He's got a Trueno AE111 blacktop.
It's one of the smaller I4's but I don't know which.(and E or A or whatever)
^ It's not a problem to check vacuum from a breather line... The oil is sucked into the intake, not blown out into the vac gauge You'll get the same reading from a brake booster line, PCV/breather line or a normal vacuum line.
Just make sure that if you take a normal vacuum line, it's not switched. Some dmigiht not have any vacuum until XXX rpm, XXX throttle, or XXX rpm @ XXX throttle.
