Fuse blows when brake pedal depressed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2005, 08:29 PM   #1 (permalink)
View Pockoleotis's Photo Gallery
Hi all.
My son has a 1985 Camry. Just recently he noticed he had no brake lights. He changed the fuse and inspected the bulbs and everything appeared ok. But when he steps on the brakes the fuse blows. All the other lights work fine. Any ideas? I'm not very good with cars and any suggestions would be appreciated. Thanks
Pockoleotis is offline   Reply With Quote
Old 01-04-2005, 08:38 PM   #2 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
sounds like a wiring short, any electrical work done lately?
Remove the bulbs in the tailight and repeat. If it still pops a fuse, its wire or switch.
Thats the best way to chase electrical, keep isolating until you are at component level.
amerikim is offline   Reply With Quote
Old 01-04-2005, 08:50 PM   #3 (permalink)
View karugs's Photo Gallery
Is it grounded properly? Are the wires connected properly? What bulbs did you install? Wattage?
karugs is offline   Reply With Quote
Old 01-06-2005, 05:56 AM   #4 (permalink)
Pockoleotis
Thanks for the tips amerikim and karugs. Traced problem to cyclops. Wire running to it from taillights was pinched in trunk mechanisim. Problem solved. Didnt know where to start. But yall put me on the right track.
Old 01-06-2005, 06:25 AM   #5 (permalink)
Gameroom cash: $124160
View CraigW's Photo Gallery
I have heard that the constant flex of those wires can lead to trouble. Glad you found it, and thanks for reporting the solution for us all.
CraigW is offline   Reply With Quote
