marks on timing belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2005, 01:04 PM   #1 (permalink)
View BobES300's Photo Gallery
I've been trying to get my belt on for about two hours... I have the cams and crank where they need to be but no matter what I do one (just one) of the marks on the belt is off one tooth ? Won't the tensioner make up the diff or does it need to be exact ? Also, can someone clarify the belt routing ? What the manual calls left and right seem to be the opposite of what I'm thinking. Is the rear/back (near the firewall) cam pulley the last thing I put the belt on or is it the front one ? Don't know if that makes a difference in my belt marks. I did check and I have it facing the right way.
thanks,
Bob
BobES300 is offline   Reply With Quote
Old 01-06-2005, 01:26 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Originally Posted by BobES300
I have the cams and crank where they need to be but no matter what I do one (just one) of the marks on the belt is off one tooth?
Forget about the marks.
Position the crank and cam pulleys where they need to be (TDC). Install the belt, rotate the crank from TDC to TDC, and check the alignment of the crank and cams (they should be at TDC).
If it doesn't line up correctly, you meesed up, and need to start all over again.
http://yotarepair.com/1FZ-ME_timingbelt.html
Right hand cam gear = rear one (the one near the firewall)
Left hand cam gear = front one
Rear.
By the way quit cross posting between here and the Lexus forum.
This is your 2nd warning.
"Skoolin' the unlearned!"
Old 01-06-2005, 07:48 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
If the cam gear keeps comming up about a half tooth off, put it AHEAD of the mark
