how much hp/tq can a 3vz and 1mz take - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2005, 07:33 PM   #1 (permalink)
View njbmx's Photo Gallery
how much can their bottomends take? i'm thinkin of doin a rebuild of my 3vz-fe motor or just thinkin of swappin a 1mz b/c of the dis ignition.
thanks
pete
*parting out the whole f'ckin CAMRY*
>pm me or im me @WINDSOR306ROUSH
'93 camry le 3vz-fe auto
hood, fenders, front clip delete
cracked winshield...all b/c of fender-bender
njbmx is offline   Reply With Quote
Old 01-06-2005, 07:43 PM   #2 (permalink)
Auto-Cross Addict
SmokingTires's Avatar
View SmokingTires's Photo Gallery
250hp or so on boost before you have to do a build. But if your building the engine with forged parts, I'm sure it could push 400+ easy. That is, if your doing a full build (cams, forged crank/pistons/rods, porting, etc)
'88 Toyota MR2 N/A - Sold
'99 Miata Sport - Sold
'85 Corolla GT-S - Sold
'02 MR2 Spyder - C-Stock car
SmokingTires is offline   Reply With Quote
Old 01-06-2005, 08:15 PM   #3 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
The cranks on a 3vz should take 400-450lb-ft
The problem with the pistons and rods are the pistons. If you lean them out too much you'll burn a hole through them.
There shouldn't be any reason why you can't get 325-375hp, with the associated amounts of torque, on the stock motor with very careful tuning.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 01-06-2005, 10:57 PM   #4 (permalink)
View wontonjohnny's Photo Gallery
lets hope so. im shooting for 350whp
5 speed 3vzfe - RIP
project F23 CL-T
Custom Y-pipe Project
Custom 1-Piece CAI Project
wontonjohnny is offline   Reply With Quote
Old 01-06-2005, 11:37 PM   #5 (permalink)
engineer in training
Gameroom cash: $145055
325-375 crank horsepower mind you of course you are manual so it will be easier, just remember to tune it and that thing should run fine with that kind of power
Old 01-06-2005, 11:50 PM   #6 (permalink)
Toysrme's Avatar
Cool
I'm not going to say that's impossible, because there are two turbo, stock motor 5vz-fe 4runners pushing 360rwhp.
But good luck reaching that goal.
Now with Turbo!
Old 01-07-2005, 09:22 AM   #7 (permalink)
Boost n' Juice Maniac
iTrader Score: 9 reviews
View trd4life's Photo Gallery
stock 1mz
I was able to get 322 crank hp and 331 tq. on my stock 1mz at 7psi with careful tuning.
1999 Solara v6 auto 13.0 @113mph s/c'd 9.5psi and nitrous
2000 Camry v6 5 speed 13.5 at 107.3mph s/c'd at 7psi
1997 Camry i4 auto to v6 auto swap! Built 3.3 3mz/1mz hybrid
trd4life is offline   Reply With Quote
Old 01-07-2005, 09:27 AM   #8 (permalink)
View mcelligott's Photo Gallery
I'll have an answer to the 3vz question when it warms up here...
Turbo 3vz-fe with Nitrous...you have questions? I have answers, Get a hold of me on aim!
mcelligott is offline   Reply With Quote
Old 01-07-2005, 10:22 AM   #9 (permalink)
same here.. cant wait... what kinda setup you doing mcelligott?
5 speed 3vzfe - RIP
project F23 CL-T
Old 01-07-2005, 10:39 AM   #10 (permalink)
Turbo froma silverado turbodiesel, its done already just gotta get my nitrous hooked back up, direct port style and replace my s-afc with something more tunable then im set.
Old 01-07-2005, 02:07 PM   #11 (permalink)
sweet... any pics to share with us??
5 speed 3vzfe - RIP
project F23 CL-T
Old 01-07-2005, 02:19 PM   #12 (permalink)
I am just a newbie!
Tony the Tiger's Avatar
View Tony the Tiger's Photo Gallery
^^ Where did you hear that? I can lean out the engine as much as I want minding you that the ignition timing is retarded enough.
And technically speaking, if you lean out the engine to the point of detonation or preignition, it will blow up regardless or being forged or not
* Goal for 2012 -- 200+ MPH in the Camry
Tony the Tiger is offline   Reply With Quote
Old 01-15-2005, 10:05 PM   #13 (permalink)
Toysrme's Avatar
Cool
Exactly right Tony.
I just happen to believe our totally iron (no coating) pistons will melt under a lean condition and poor tuning because of in-experianced tuners, rather than be detonated to pieces from poor ignition timing/pre-ignition problems.
Remember you atleast get the benifit of whatever type of coating is on the face of yours. When I knocked the built up carbon off my 3vz-fe pistons, they was no helpful ceramic coating. I've never seen OEM 3vz-fe pistons out of the engine, but I have seen both OEM and aftermarket 3vz-e pistons. 100% cast iron with no coatings what so ever.
I'll be the first to argue with good tuning a 3vz-fe can match your original turbo upgrade of 375 crank horsepower, I just happen to think you had a lot of little help on the piston side!
Judging by the same-technology dead 5vz-fe's, and 5s-fe's It seems to me the #1 cause of engine failure is a poor A/F mixture (or unknown failure causing an incorrect mixture) in a piston, blowing a hole in it.
That's just my opinion from watching a bunch of other projects, but hey! I'm probably wrong if you say the rods/pins will bust first from too much power, or detonation problems!
Remember you also have one thing noone else (but probably McElligott) has... Neither of you are newbies to higher horsepower, or boosted engines. There is no substitute for experiance. You're both living proof of it.
Tell ya what, if no real-life issues come up, Sean McElligott oughta be done with his 3vz-fe Turbo kit sometime in the comming week. (Monday at the soonest) Wanna put some pride on the line to bet what, if anything, let's go before he declairs the kit to have "enough power" and "safe to sell"???
Now with Turbo!
Old 01-16-2005, 01:18 AM   #14 (permalink)
Word, super close to making a thread on here with all the finalized pics n such...
Old 01-16-2005, 01:28 AM   #15 (permalink)
Guess whos back
View CamryWhat?'s Photo Gallery
so....wait how would i not blow my 5sfe up with a turbo lol....This sounds like it could be bad!
2000 VW Golf: CAI Exhaust 18's Koni/Nuespeed
92 Camry- No motor Stock and Stock!
CamryWhat? is offline   Reply With Quote
