engine rebuild questions plz help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-07-2005, 07:17 PM   #1 (permalink)
bt6
View bt6's Photo Gallery
what's up everybody,
i blew my head gasket and bent a rod last weekend, so i am now having my engine totally torn down and rebuilt. Here's where the help is needed i am planning on adding the rippmod supercharger eventually, what should i have done during the rebuild process to help prepare for it. Porting, polishing, bore out the block??? If anyone could give me any pros, cons, and benefits of the work i'd appreciate it.
thanks,
brian
bt6 is offline   Reply With Quote
Old 01-07-2005, 07:59 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
lets start with what motor are you building up?
Old 01-07-2005, 08:06 PM   #3 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
first of all, you should do a lot more research.
1) Porting and polishing (generally both go together), are done on the heads, not on the block.
2) Many of these topics have been covered and beaten to death.
3) As with any boosting (you could've easily searched and found this again), lower CR will help you out with boosting much more.
I think before you consider the rippmods kit, you should invest some time in researching everything that goes into installing it, operating it and contributing to its performance.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 01-07-2005, 08:09 PM   #4 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
thanks,
brian
Brian;
let me know ... if you want me to help ... I currently helping Allen with his rebuild...
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 01-07-2005, 11:44 PM   #5 (permalink)
Gameroom cash: $147537
Since someone started it, I'll highjack the thread.
I wanna do all NA on the 5S-FE. I can get P&P but looking for high CR piston and regrind cams. I gonna keep the ECT auto tranny, don't want manual swap. What CR should I go? What cam should I get? Where can I get them?
Will have header from 3S-GE, TechTom ECU and 3S-GTE fuel pump also.
Old 01-08-2005, 07:56 AM   #6 (permalink)
The Other White Meat
terrastrife's Avatar
11:1+ CR depending on wha tfuel you want to run. cams? get your current cams re grinded. if you rmotor is non interference you can grind down teh head to increase CR. cams can be reprofiled at many places... but expect delays (im getting Crow Cams to do mine, as theyve already done a 3VZ profile b4). other things such as better head gaskets, and your ecu of choise too to be considered. cams wont require you to take teh head off, where as a port or new pistons/whatever for higher CR will.
terrastrife is offline   Reply With Quote
