160k 3VZ Smoking, Starting Hard - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2005, 01:59 PM   #1 (permalink)
Crossdrilled and Slotted
View myconid's Photo Gallery
I have a 1992 3VZ-FE with about 160k on it. When I start it, it usually seems to puff a little blue smoke out. Lately, I have had a problem with possibly my ignition. I crank it for ~20 seconds, and then stop. Out the tailpipe comes blueish smoke. I left on vacation for 3 days, came home, and it wouldnt start at all. It would turn over, but not start up. The main wire to the distributor looked damaged, so i straighened out the prongs, and without a spare in sight, put it back in until I can replace it. It took me about 30 seconds of starting it then it started to catch.. then a little more.. then it seemed like it was firing on 3 cylenders maybe.. then eventually it brought the idle up to ~2k, then dropped to 800 rpm and it seems ok.
Am I losing my headgasket? Any other ideas? I have this sludgy stuff around my motor.. is it just oil & dirt?
myconid is offline   Reply With Quote
Old 01-09-2005, 05:25 PM   #2 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
It's not your head gasket thats going out, looks like its from the oil filler hole. Look at where the oil seems to be originating from. Replace that cap first.
Are you overfilled? Thats a big
Then clean that f*'ing mess up.
Next in line would be your cam cover gaskets.
I am sure they are shot too but best to do one step at a time.
I honestly do not think your head gaskets are going.
Get a decent set of plug wires in and change your plugs. If your wires are messed up, I bet thats unburnt gas smoking there. Add the oil leaking onto your header pipes and your ride must smell like Iraq.
Whens the last time that car has been in for a good service? If you are not mechanically inclined, it may be better for you to keep that car regularly serviced by a professional. I am not flaming you, but trying to get you another hundred thousand miles out of it.
amerikim is offline   Reply With Quote
Old 01-09-2005, 06:26 PM   #3 (permalink)
engineer in training
Gameroom cash: $145055
Have you changed your rotor and distributor cap? It may be time to invest $20 and replace those, its very easy to do and doesnt take much time at all, it really made my engine run a lot better
edit: the smoking is you valve guide seals, it happens with mileage and isnt an easy fix
Old 01-10-2005, 01:04 AM   #4 (permalink)
View wontonjohnny's Photo Gallery
your gonna make me cry ... hate to see a neglected 3vzfe.
5 speed 3vzfe - RIP
project F23 CL-T
Custom Y-pipe Project
Custom 1-Piece CAI Project
wontonjohnny is offline   Reply With Quote
Old 01-10-2005, 09:12 AM   #5 (permalink)
I clean my engine every spring.. I live in Vermont and travel dirt roads regularly... That is just built up gunk. I cleaned everything that I could get to off, but the rest will need to wait until spring.
Old 01-10-2005, 10:14 AM   #6 (permalink)
View mcelligott's Photo Gallery
no that's definitely leaking oil, not built up road gunk.
Turbo 3vz-fe with Nitrous...you have questions? I have answers, Get a hold of me on aim!
mcelligott is offline   Reply With Quote
Old 01-10-2005, 10:56 AM   #7 (permalink)
97 BlackWidowed
View Porkch0p220's Photo Gallery
oil's coming out of some were.........
Porkch0p220 is offline   Reply With Quote
Old 01-10-2005, 04:37 PM   #8 (permalink)
Powered by Soundstream
View AMScamrySE's Photo Gallery
Looks to me like the valve cover gasket, or like amerkim said it could be your oil cap.
AMScamrySE is offline   Reply With Quote
Old 01-10-2005, 05:06 PM   #9 (permalink)
Its freakin hot here...
View ArmyofOne's Photo Gallery
the little bit of smoke you get on startup (normally) is ususally valve stem seals or piston rings showing their age. camry engines are known for their longevity, so it would actually suprise me if this is the case. with 160K miles, she should still be in her prime, there are many around here with well over 200K and a few with over 300K on their camrys.
i agree with the above statement, PCV VALVE, plugs, wires, valve cover gasket, (ask the guy at autozone for a cam cover gasket and he will probably give you a wierd look LOL) and distributor/coil can be done for about $100 and a day of your time.
has the PCV valve ever been changed? the reason i ask is this:
a PCV valve is a Positive Crankcase Ventilation valve. it vents the Excess pressure from the engine and puts it back into the intake, where it is burned. when they clog (typically every 65-85K), they cant vent the excess pressure, it has nowhere to go but out of the seals. this causes leaks, and fortunately, the ones that usually go first are the valve cover gaskets, because they are closest to the valve. they are also easier than say, the rear main seal to repair.
2006 Honda Civic EX in Galaxy Gray Metallic Pearl-WR Blue Brake Calipers, Ipod Integration, Debadged, K&N Drop-In, Mobil 1 Synthetic oil, Bridgestone Turanza 215-55-R16 Shoes, RedStuff Ceramic Brake Pads, Tint w/3m SolarGaurd film: 5% rear, 15% front, 30% moonroof
ArmyofOne is offline   Reply With Quote
