Power Steering Fluid Drain-Fill - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-10-2005, 01:22 PM   #1 (permalink)
Toyota-Lexus Fanatic
mandyfig's Avatar
View mandyfig's Photo Gallery
Power Steering Fluid change. 1995 Camry.
Somebody's done this? I have instructions but still a bit confused, and would appreciate advise from members who have done it. The fluid is the same as transmission fluid, Dexron III, might be a good idea to drain and fill to keep it fresh. Mine looks like cruddy, it is supposed to be pinkish in color.
Thanks.
mandyfig is offline   Reply With Quote
Old 01-10-2005, 02:18 PM   #2 (permalink)
View 04sev6camry's Photo Gallery
if it looks bad then yes u should change it. ive changed it on a chevy 350 before, but its a little different than toyotas system, so im not exactly sure about how to do it for your camry
04sev6camry is offline   Reply With Quote
Old 01-11-2005, 10:31 AM   #3 (permalink)
View ruoknow's Photo Gallery
jack up the car
1. drain (by siphon) the PS reservoir as clean as you can
2. unplug the lower line (ps fluid will pumped out from here), use some tygon tubing to extend it into a drain pan (just like the one you do you oil change)
3. fill the reservoir and ready to fill more (stand beside the PS reservoir with a full bottle of Dextron III in your hand and ready to pour)
4. crank the car: you will see how fast it pumps
5. repeak until clean
6. hook up the lower line, fill the reservoir
7. rock the steeling wheel from stop to stop to work the air out.
done!
ruoknow is offline   Reply With Quote
Old 01-11-2005, 01:43 PM   #4 (permalink)
mandyfig's Avatar
Thanks a lot.
