cams for 3s-fe - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2005, 06:33 AM   #1 (permalink)
Ultima's Avatar
View Ultima's Photo Gallery
Australia cams for 3s-fe
Hey everyone! I am wanting to put sports cams into my 3s-fe motor, however i cant find any suppliers in oz. can anyone help? or does anyone know if i can grind my cams to be similar to the 3s-ge cams? (and if so what measurements that would be?)
y be like dat for?
Ultima is offline   Reply With Quote
Old 01-11-2005, 09:44 AM   #2 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
There aren't any.
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 01-11-2005, 09:59 AM   #3 (permalink)
View Camry Marc's Photo Gallery
I dont think grinding your cam is a good idea lol, since most of the performance cam are mare to be longer so the valve are opened longer and etc... i'm not going to get in details but grinding is bad unless you are an expert and you know how to do it perfectly like the 3s-ge cam go ahead. damn first time i ever heard someone who whant to grind his cam
Camry Marc is offline   Reply With Quote
Old 01-11-2005, 10:10 AM   #4 (permalink)
Gameroom cash: $147537
Do a search for 5S-FE cams. The company could custom grind you a set for 3S-FE.
Old 01-11-2005, 10:18 AM   #5 (permalink)
userlain's Avatar
Is that possible? I always thought the 3SFE wasn't true DOHC, but the 5SFE was...
Old 01-11-2005, 10:22 AM   #6 (permalink)
i dont know but it should work, is this was the motor that we can frankenstein ? the 5s-fe with the 3s-fe ???
Old 01-11-2005, 11:49 AM   #7 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
I don't know about OZ, but contact Crower or Web Cam Inc.
http://www.crower.com
http://www.webcamshafts.com
3S-FE and 5S-FE are DOHC. However theres only one camgear (on the intake cam).
The intake cam drives the exhaust cam thru a internal gear on both cams.
G head design (3S-GE/GTE, 7M-GE/GTE, 2JZ-GE/GTE, etc...) is true DOHC. Each cam has its own camgear. The G head design also has a wider valve angle (45 degrees) vs. the F head (22 degrees) design.
No.
The cams on the 5S-FE are different then the ones on a 3S-FE.
Bore and stroke on a 5S-FE is bigger then a 3S-FE.
5S crank has bigger rod journals.
"Skoolin' the unlearned!"
Old 01-11-2005, 12:08 PM   #8 (permalink)
nice info, thanks
Old 01-11-2005, 03:59 PM   #9 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
You can't use 3SGE cams with the 3SFE?
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 01-11-2005, 04:07 PM   #10 (permalink)
Nop. GE cam are driven by 2 cam pulley outside the cover. FE use one pulley to drive one cam and gear on that cam drive the other cam.
This is FE cams:
See the gear connecting both cams.
Now someone post GE cams
Old 01-11-2005, 04:30 PM   #11 (permalink)
Grenaded piston
88 LE's Avatar
3S-GTE:
Notice how it has 2 camgears and no internal gears on the cams.
Exhaust cam = top part of picture
Intake cam = bottom part of picture
Old 01-11-2005, 04:50 PM   #12 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
well arent there maching shops that can build back up the metal on the cams and then regrind them back down ..... i rember my dads friend telling us about this to rebuild a shaft for a distrobuter and water pump
^ and leaving it that way!
Old 01-11-2005, 05:13 PM   #13 (permalink)
Grenaded piston
88 LE's Avatar
^ They weld the lobes of the cam, then regrind it.
Thats why its called a regrind.
Old 01-11-2005, 05:18 PM   #14 (permalink)
VeeZed
Apart from the GE head having a valve angle of 45 degrees, what is the idea behind having no internal gear like that, and having them driven seperatly?
My 2VZFE is like that first picture, (obviosuly because it's a FE!!) Interesting to see they follow very similar principles. I assume 3SFE and 2VZ cams are different..and that 3SGE cams will not work wit my 2VZ. I too am reserching better cams for my engine. Any ideas?
Old 01-11-2005, 05:28 PM   #15 (permalink)
Pulling Out
View S2B_Blown_3.5's Photo Gallery
Correct, each camshaft on your engine drives the valves for 3 cylinders, the 5S and 3S cams drive 4. I don't know of anyone who makes 2VZ cams, you might have to look into regrinding.
-=MANUAL TRANSMISSIONS=-
Both hands on the wheel, shift with your Johnson!
S2B_Blown_3.5 is offline   Reply With Quote
