Should I or Not? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2005, 07:04 AM   #1 (permalink)
View camlex's Photo Gallery
Should I or Not?
I have 97 1MZfe V6 Engine and rear Valve cover gasket is leaking.
This leak is not really bad. but i wants to fix it. I did search on this subject. not enough info.
I like to know step by step working flow.
Mechenic is asking for $ 300.
Is it a easy job?
While changing valve cover i also wants to change sprark plug,Spenum & other gasket.
please tell me which tools i will need. and some step by step instruction.
Thanks in advance.
camlex is offline   Reply With Quote
Old 01-11-2005, 08:51 AM   #2 (permalink)
TN's Financial Expert
BullMarket's Avatar
View BullMarket's Photo Gallery
A haynes manual or chiltons is a great way to start...you will never look back($14). Look to autozone.com they *I believe* post chilton's up.
BULLMKT
SFTIEREEL
BullMarket is offline   Reply With Quote
Old 01-11-2005, 09:27 AM   #3 (permalink)
Gameroom cash: $147537
Valve cover should be easy. $300 is way too much.
Old 01-11-2005, 10:07 AM   #4 (permalink)
View ruoknow's Photo Gallery
The rear bank on 1mzfe is a bear!
the heynes manul is not very clear about how to remove the wiring harness and the lines attached to the intake plenum.
I got the same problem(rear bank valve cover leaking) and want to do the same thing (change spark plugs). We will see if somebody can enlighten us.....
300 quote for replacing the gasket and all the spark plugs, i will say it's a ok price....
200 bucks will be better though....
ruoknow is offline   Reply With Quote
Old 01-11-2005, 10:10 AM   #5 (permalink)
View Camry Marc's Photo Gallery
i agree with ruoknow the rear is a pain in the ass on the 1mz-fe maybe that's why they ask 300$ since it's not really accessible and the time to do it will be long
Camry Marc is offline   Reply With Quote
Old 01-11-2005, 10:14 AM   #6 (permalink)
BullMarket's Avatar
the heynes manul is not very clear about how to remove the wiring harness and the lines attached to the intake plenum.....
Factory service manual they run about $100 or so...still beats $300 (ebay..88le knows his handle on ebay)
Call more than one shop...if you get similar quotes then that's what youre gonna have to pay...unless you do it by yourself.
BULLMKT
SFTIEREEL
