rainy weather problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2005, 03:33 AM   #1 (permalink)
40x40 pixels is crap !
Velox_camry's Avatar
View Velox_camry's Photo Gallery
i was just wondering if anyone of your camry kids out there is having problems with weird noises since its been raining ( mostly so cal) anyways i have this weird sloshy squeek noise when i slam on the brake and or take off semi fast it sounds like something sloshing in the trunk then i hear a weird constant swaying squeek noise for about 5 secs after ive stopped. i thought to check for flooding in the trunk, and there was... there was about a quart of water in the trunk. i cleaned it out and tried to drive around again and the noise is still going on. any ideas on what to do ? the noise sounds like it coming mostly from the right rear side
"Guardrails...those things that separate the men from the boys."-Fumiaki Komatsu
Velox_camry is offline   Reply With Quote
Old 01-12-2005, 06:40 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
you have a leak good sir. check the antenna mast might be leaking from there. a quick trip to your local part store and some insta-gasket you should be good to go!
^ and leaving it that way!
Old 01-12-2005, 08:11 PM   #3 (permalink)
View karugs's Photo Gallery
Antenna grommet, taillight seals, and trunk seals. I would also check the rear windshield seal as well just in case it isn't any of those three. If it's still not any of them I would check the floor drain plugs--water might be going in from there when you pass flooded areas.
karugs is offline   Reply With Quote
