End link question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2005, 06:52 AM   #1 (permalink)
View slosh's Photo Gallery
Question End link question
My g/f has a 98 camry I4 with the infamous clunk in the trunk sound. She had new struts put on (sears, never again) and last night I replaced the swaybar bushings. Still clunking. I noticed that when I hit the swaybar the rear passenger end link rattles, but it's not a deep clunking noise. Maybe it is with 2000 pounds of force going over a bump, I don't know. Do you think that's the cause of the clunk? The top of the end link wasn't tight. I could turn the bolt around with my hand. How can I tighten it or do I need a whole new end link? Thanks a bunch!
slosh is offline   Reply With Quote
Old 01-12-2005, 07:34 AM   #2 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Maybe, jack the car up and see...
Most of the time the bolts are nearly frozen on via rust so they don't move, but she may have a loose bolt on one of the end links, or she may be missing an end link bolt completely.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 01-12-2005, 10:31 AM   #3 (permalink)
I did jack it up and look at it and I couldn't figure out how to tighten up the top end link bolt. I read something on here about an hex hole and a wrench. I'm assuming that's how I'm supposed to tighten it. Last night I didn't see the hex hole. When I say I can turn the top end link bolt with my hand, I mean I grab the nut and turn and the nut, bolt, and weird bolt head turns. I'm assuming it's not supposed to do that. Does that mean it's stripped or just not tight enough?
Old 01-12-2005, 10:39 AM   #4 (permalink)
View burchard's Photo Gallery
If you can turn the bolt with your hand,most probably that's the cause of the clunk. Try to tight it. I would put some penetrating oil or any of those liquid wrench products and then tight the end link holding the bolt with an hex tool while turning the nut. A torque of 47 ft.lbf is enough if you are able to move the nut. That's more o less half the torque that you apply to the wheel nuts.
burchard is offline   Reply With Quote
Old 01-12-2005, 12:08 PM   #5 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
You need a 5mm allen wrench and a 12mm or 14mm (I forget which) closed end wrench.
If you look in the middle of the nut you'll see a stud with a hole in it. A allen wrench fits into this hole.
Use the allen wrench to hold the stud still while you tighten the nut.
"Skoolin' the unlearned!"
Old 01-12-2005, 02:19 PM   #6 (permalink)
Thanks guys! I'll give it another go tonight after work. This site rocks
Old 01-12-2005, 03:19 PM   #7 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112650
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
Thats your problem. ...the endlink. The bushing is shot.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 01-15-2005, 03:30 PM   #8 (permalink)
I wanted to try and tighten the bolt up first just in case that's all it was but the d@mn thing is stripped. Any tips or tricks to tighten her up?
Bluemeanie, I notice you're from St Louie. We're practically neighbors.
Old 01-17-2005, 09:05 AM   #9 (permalink)
The way I did it: I slide back the boot of the endlink bushing and hold the endlink with a 1-2 mm good grasping appliance. Try tu unscrew first.
Old 02-02-2005, 10:37 PM   #10 (permalink)
Follow up - Finally got around to putting on new endlinks and that fixed the problem. Thanks for the help fellas!
Old 02-02-2005, 11:09 PM   #11 (permalink)
Toysrme's Avatar
Cool
Good deal!
Now with Turbo!
Old 02-03-2005, 10:45 AM   #12 (permalink)
that guy
View xylium's Photo Gallery
I was curoius where we could get rear endlinks for the 92-96 for cheap. The cheapest place I have found was ebay $60 for a pair. The toyota dealer wants $80 each and CT motorsports wants $80 for a pair. Has anyone found these cheaper anywhere else? It looks like we have to replace the whole link and we can't just replace the bushings, is that correct? Also, curious about the sway bar bushing, the one between the bar and chassis.
Totally stock 00' 4cyl in Sage. Looking for set of nice stock 15" alloys for cheap, got any?
xylium is offline   Reply With Quote
Old 02-03-2005, 11:39 AM   #13 (permalink)
I bought my endlinks from ebay and am happy with them. You're correct - you can't just get bushings for the end links unfortunately. The sway bar bushings are cheap from any parts store. I think I got mine from Auto Zone for $4 each.
Old 02-03-2005, 11:55 AM   #14 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
you got PM
