Hood Rattling noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2005, 08:58 AM   #1 (permalink)
View rainman's Photo Gallery
Arrow Hood Rattling noise
My 95 V4, has a peculiar problem where the hood keeps giving out a rattling "tuk..tuk...tuk" noise, each time I hit a bump or hole - big or small. The hood does lock properly but not tight enough to avoid any movement. So whenever there is a jerk... the hood goes rattling ...moving and rattling itself..hitting somewhere inside.... I have no clue where..
Could you guys help me figure this one out... any help is appreciated...
rainman is offline   Reply With Quote
Old 01-12-2005, 09:03 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
you have an I4 .......
make sure the bolts at that hold it to the car are tight and make sure it's not your springs for your suspension making that noise
^ and leaving it that way!
Old 01-12-2005, 09:08 AM   #3 (permalink)
Hey Thanks for the reply...But, No its not from the Suspension, coz I could see the hood moving up and down due to the airflow during driving and the noise coincides with this moving and also..the noise is the same when I jerk the hood alone while stationery...
BTW, whats an I4
Old 01-12-2005, 09:11 AM   #4 (permalink)
96 3MZ M/T
chronoti's Avatar
inline 4 the cylinders are in a stright row, while a v the cylinders are set oposting each other in a v shape with equil numbers on each side, h, flat, boxer, what ever you would like to call it is similar to the v but the cylinders sit flat opostin each other
http://auto.howstuffworks.com/engine5.htm
Old 01-12-2005, 09:15 AM   #5 (permalink)
Ok Thanks!!..I'll check the bolts today...
Old 01-12-2005, 10:02 AM   #6 (permalink)
View 500KCamry's Photo Gallery
At either end of the frame that holds the radiator are two rubberized bumpers, they screw out using your fingers, and contact the hood when it is closed. This stops the hood from rattling when latched and causes it to pop up when you use the hood release. Maybe the bumpers need to be turned counter-clockwise a turn or two?
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 01-12-2005, 12:51 PM   #7 (permalink)
Hey Thanks!! Turning the bumpers solve the problem... now the car rides smooth.
