Replacing no. 2 shift solonoid - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2005, 02:46 PM   #1 (permalink)
R/C Junkie
View Smiff 24's Photo Gallery
I have a 94 camry le 5s-fe w/auto tranny
ive got to replace the #2 shift solonoid, trouble code 63
symptoms are,, every once in a while when starting out in D, the trans will shutter
pretty bad.....when it does this you can put it in 1 and manually go thru the gears and it will accelerate just fine.
anyone had this before ?
any help would be appreciated.
Smiff 24 is offline   Reply With Quote
Old 01-12-2005, 11:12 PM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
adjust your kick down cable will help some.
i personly dont advise working on a auto tranny unless you know what you are doing
^ and leaving it that way!
Old 01-13-2005, 11:39 AM   #3 (permalink)
Post Hoc Ergo Propter Hoc
Bishop13's Avatar
View Bishop13's Photo Gallery
Yeah, i have the same problem and apparently the solenoid is inside the transmission bellhousing, so that is probably a job best left to a tranny shop. The estimates/quotes I've gotten here in So. Cal are around 250-350 for parts & labor.
Capitalization is the difference between helping your uncle Jack off a horse, and helping your uncle jack off a horse
1997 Toyota Camry LE / 2001 Land Rover Discovery II / 2006 Audi A4
http://www.flickr.com/photos/henryenriquez/
Bishop13 is offline   Reply With Quote
Old 01-13-2005, 12:11 PM   #4 (permalink)
tC
View 95camguy's Photo Gallery
auto trans are tough to work on unless you know what you are doing. on my last car, a vw passat, they apparently thought the oridinary public wasnt even capable of checking the fluid level. no dipstick on the 97 passat trans. sorry for the needless complaining.
...u should definetly have it checked out
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline   Reply With Quote
