What 500KCamry said.
You need a/f mixture, spark at the right time, and compression to run.
Also the ECU will refuse to send ignition signals is XXX rpm isn't achive during cranking.
Battery terminals would be a great palce to start. Check the battery itself also. Make sure it has the correct amount of fluid if it's serviceable.
AIM/Yahoo Toysrme257th
Now with Turbo!
