Help on 2nd gen camry front speakers - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2005, 09:37 PM   #1 (permalink)
I'm Randy
illusive562's Avatar
View illusive562's Photo Gallery
hey everyone, sorry for the noob comment im going to ask...the front speakers on my camry are 3 1/2 mounted in somekinda of box with a 4 inch cap at then end thats pushable that blocks the air flow i guess...i replaced my stock speakers with some 3 1/2 inch audiobahns and is it best to leave that 4 inch cap on or take it off? do my speakers need room to breathe?
illusive562 is offline   Reply With Quote
Old 01-13-2005, 10:41 PM   #2 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
*Edit*
Hawkeye's right, I didn't realize we are talking about a gen2 LoL
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 01-13-2005, 10:56 PM   #3 (permalink)
Hawkeye-SE's Avatar
View Hawkeye-SE's Photo Gallery
That "four inch cap" is a passive radiator. Leave it, it helps bass a lot. Its not very different than a ported box. The problem is that they are tuned to the stock speakers, but you will be better off leaving it intact.
Its actually not a terrible design, its limited by a 3.5 inch speaker though. There is some problem with phase too, but nothing anyone notices unless you have a keen ear and are really paying attention.
Toysrme - what are you talking about? Gen 2 speakers are in the bottom of the dash.
Hawkeye-SE is offline   Reply With Quote
Old 01-13-2005, 11:14 PM   #4 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
I replaced the passive radiator with 4" speakers
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 01-14-2005, 12:06 AM   #5 (permalink)
I'm Randy
since the speakers for the fronts are only 3 1/2...do i still need to amp it up? i jsut got my system installed yesterday and i have a 5 channel 1300 watt amp...200 x 4 adn 500 x 1...what i did was amp the rears with the first two channels and bridged the 3rd and 4th to one sub and use the 5th channel which is 500 watt for my second sub...i left the fronts not amped at all...is it better to amp it up? or leave it alone...thank you
Old 01-25-2005, 08:10 AM   #6 (permalink)
View soupster's Photo Gallery
Can someone please tell me how to remove/replace the front speakers? I removed the grill and the single bolt, but I cannot get to the speakers. Thanks!
soupster is offline   Reply With Quote
Old 01-25-2005, 09:29 AM   #7 (permalink)
View treecitybusa's Photo Gallery
I believe that you have to remove the lower panel to get to it. Couple of more bolts and you will have it.
treecitybusa is offline   Reply With Quote
Old 01-25-2005, 12:26 PM   #8 (permalink)
Always Under Construction
View whocares04's Photo Gallery
if you have an aftermarket headunit, most have a built-in amp pushing 25-50W RMS which is enough for the fronts unless they are top top of the line capable of 100W RMS or more (unlikely). also, be careful tuning ur rear speakers that are amped b/c i put a small tear in my rear 6x9s because i put too much power in them for bass.
also, since you have subs, i would turn off the bass to the rears and front b/c the subs will cover the bass just fine and use speakers for only mids & highs.
just my suggestions (that worked in my car)
-Matt
When in doubt, use the search function (link)...no one is spoon fed...
whocares04 is offline   Reply With Quote
Old 01-25-2005, 07:04 PM   #9 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Drivers side
1. Bolt behind the speaker grill.
2. Pop off the panels (dimmer & cruise control) next to the steering column. Theres bolts hidden behind these panels.
3. Black plastic panel on the bottom of the dash. 2 screws.
4. 2 screws for the hood release latch.
5. A few more bolts on the bottom corners of the dash.
Passenger side
2. A few screws for the glove box door.
3. Pull out the glove box and pull the plug for the glove box light and switch.
4. Black plastic panel at the bottom of the dash. Its held on with 3 clips, just pull on it and it'll pop off.
5. I think theres a few screws/bolts around the glove box opening.
6. A few bolts on the bottom corners of the dash.
"Skoolin' the unlearned!"
Old 01-25-2005, 07:20 PM   #10 (permalink)
Thanks 88 LE!
After reading all around this site and seeing some door installs, I'm really thinking the doors are the better option. What size speaker can I cram in place of the map pocket?
Old 01-25-2005, 07:37 PM   #11 (permalink)
Grenaded piston
88 LE's Avatar
Thanks 88 LE!
No prob.
I built a panel that replaces the map pocket. It houses a 5 1/4" mid (Oz Audio).
A 6.5" will fit too, but you have to build the panel out so that you'll have enough room to mount the speaker.
Some pics of my door panels:
Old 01-25-2005, 09:58 PM   #12 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
Had to do the shameless plug for my own install....lol
but this is how 6.5's can be done.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 01-25-2005, 10:03 PM   #13 (permalink)
Its freakin hot here...
View ArmyofOne's Photo Gallery
wait? you can connect an aftermarket HU to a stock amplifier?
2006 Honda Civic EX in Galaxy Gray Metallic Pearl-WR Blue Brake Calipers, Ipod Integration, Debadged, K&N Drop-In, Mobil 1 Synthetic oil, Bridgestone Turanza 215-55-R16 Shoes, RedStuff Ceramic Brake Pads, Tint w/3m SolarGaurd film: 5% rear, 15% front, 30% moonroof
ArmyofOne is offline   Reply With Quote
