Need help w/ glow gauges - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-14-2005, 07:59 AM   #1 (permalink)
View Paul95's Photo Gallery
Angry Need help w/ glow gauges
hey guys i'm a n00b here.
I went to install some reverse glow gauges on my 95 camry dx.
i took out the tack and the speedo to get to the screws for the fuel & temp. did those too then i put the tach/speedo back in. slide the gauges on. Never took off the needles. but they did more around a bit.
they light up fine but the tach won't move
and neither will the speedo
i believe the other 2 gauges are working fine. i only drove it once and it's sitting at home till i can fix it.
Also the lights on my hvac are not on. I dont remember unpluggin those either.
Can someone help?
Paul95 is offline   Reply With Quote
Old 01-14-2005, 09:41 AM   #2 (permalink)
Driving Like It's Stolen
View Beez97Cam's Photo Gallery
Did you tape or glue the new gauge faces to the existing? Make sure the glow face(s) haven't come unstuck & bubbled up - could be rubbing the needle or keeping it from moving freely.
Gen4 Camry 5SFE ('97). All stock now but not for long...
Karma's a bitch, ain't it?
Beez97Cam is offline   Reply With Quote
Old 01-14-2005, 10:26 AM   #3 (permalink)
no i didn't tape them down. i will go back and try to do that tonight. but i know that they are not touching at all.
and what else is odd is that my hvac lights didn't come back on after the install.
Old 01-14-2005, 01:10 PM   #4 (permalink)
bump for some more help
Old 01-14-2005, 02:27 PM   #5 (permalink)
Eaten iVtecs before!
View coolchu001's Photo Gallery
Well i've installed it on my car as well, just tape the faces down with double side tape, and then move the needles around to see if it has any nags and or pauses...if its smooth then it should move, be sure that u screw the tach and speedo on the clauster tightly
coolchu001 is offline   Reply With Quote
Old 01-14-2005, 02:39 PM   #6 (permalink)
TN's Nikon Expert?
prnc_chrmng's Avatar
Gameroom cash: $491868
View prnc_chrmng's Photo Gallery
yeah, make sure the black thing the need goes into isnt catching on the new guages, i used regular double sided tape and havent had a problem since.
Originally Posted by 98tercel_girlie
This thread needs more porn, less blah blah
prnc_chrmng is offline   Reply With Quote
Old 01-14-2005, 04:43 PM   #7 (permalink)
the only screw holes are in the temp and fuel gauge.
btw after you slide the needle around did you have to put back on the bottom bar, or did it move by itself?
I dont think anything is catching at all. but i'm going to double check everything out tonight when i get home.
did you guys move your needles freely and not have a problem at all? or did you remove your needles?
Old 01-14-2005, 05:25 PM   #8 (permalink)
View l0n3xstar's Photo Gallery
i had a problem like this also. except mine never stuck on well with a double sided tape. every single time it kept getting a lil loose then it catches on the needle not causing it to move. if tape doesnt work for u, try glue. juss elmers glue.
and dont remove ur needles and yes it should move freely back to its original position.
l0n3xstar is offline   Reply With Quote
Old 01-14-2005, 06:38 PM   #9 (permalink)
any chance they would have to be recalibrated?
cuz if that's the case i think i may just buy another cluster and say forget bout the gauges
Old 01-14-2005, 07:20 PM   #10 (permalink)
限界域への独走。
View mobes's Photo Gallery
No. Try checking your fuses.
mobes is offline   Reply With Quote
Old 01-15-2005, 12:51 AM   #11 (permalink)
TN's Nikon Expert?
i think i made sure to tape well around the needle thing (its hours later and i still cant think what its called...) just make sure the tape doesnt overlap it self. i had a problem with my needle being "sticky" when i first installed my guages, and it was only the tinyest part that was catching.
Old 01-16-2005, 05:32 PM   #12 (permalink)
ok guys i tried the tape thing and it didnt' work.
but super glue worked awesome. they work perfect thankx for the help.
only question i have now is. that my hvac lights dont work. i am wondering if it's just those or the ones behind the glow gauges too.
anyone know where that fuse is for those or what else it could be?
