E-Brake Light Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-16-2005, 08:16 PM   #1 (permalink)
View dj justice's Photo Gallery
I have a 1999 Camry Le and recently the e-brake light will come on for a brief period of time and then turn off when the ebrake is fully depressed. What does this mean?
dj justice is offline   Reply With Quote
Old 01-17-2005, 12:48 AM   #2 (permalink)
^In College
View btrek's Photo Gallery
Your brake fluid is low
this has been discussed many times-- try using the search function next time
Yea-----BT
btrek is offline   Reply With Quote
Old 01-17-2005, 02:14 AM   #3 (permalink)
View 500KCamry's Photo Gallery
Another tid bit I did not know. Thanks.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
Old 01-17-2005, 05:25 AM   #4 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
Yeah this has come up countless amount of times before.
http://www.xclusive.bz
Old 01-17-2005, 02:40 PM   #5 (permalink)
View anuthaCamry's Photo Gallery
my fuel light comes on sometime too
anuthaCamry is offline   Reply With Quote
Old 01-17-2005, 07:22 PM   #6 (permalink)
tC
View 95camguy's Photo Gallery
07 tC MT
-TRD RSB
-TRD Quick Shift Kit
-TRD Exhaust
95camguy is offline   Reply With Quote
Old 01-20-2005, 03:06 PM   #7 (permalink)
Yeah i tried searching with no luck. So if the brake fluid is low that means its leaking somewhere right? This is actually my gf's car. I have a 4th gen accord.
Old 01-20-2005, 03:41 PM   #8 (permalink)
really, brake problems could be really serious. I recommend taking it to an ASE certified mechanic at once.
my worst brake problem was a sheared o-ring in the master cylinder of this old 3ton car I used to have long ago. i signalled right and was about to turn but the brake pedal hit the floor with no brake effect at all so I just went straight (no choice). after a few pumps it worked perfectly - but I drove no more than 2 miles on it before changing the master cylinder. I took it apart and i saw that one of the o-rings in the piston had a perfect geometric chord on it. To make things worse, it was a dual master too.
if the fluid is low that could be from worn disk brakes because brake fluid makes up for brake wear within those systems. my brake fluid was low too the other month, so I bleeded the brakes (they were dirty) and measured the thickness of the rotors and pads and they were almost totally worn down (.001 over)
add very clean fluid, brand new dot3 and don't get no dirt in the fluid. then take it to your mechanic
fyi, that is NOT and e-brake light, it is a brake trouble light and it's primary purpose is to indicate a brake fluid problem
