replacing brake light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-17-2005, 10:32 AM   #1 (permalink)
View Kathy's Photo Gallery
Hi,
I have a 1995 Camry, and the right brake light needs to be replaced. My manual shows two screws when the trunk is opened. I don't have that.
Do I go in through the trunk?
Do I jimmy the light compartment with a screwdriver?
Please help.
Kathy
Kathy is offline   Reply With Quote
Old 01-17-2005, 10:36 AM   #2 (permalink)
5sp 3VZ-FE
mescalito's Avatar
View mescalito's Photo Gallery
hey! welcome to TN
there SHOULD be two screws holding the unit in place - open the trunk and look to the right where the housing for the light is - should be two screws and once they are off, the complete unit can come out...
mescalito is offline   Reply With Quote
Old 01-17-2005, 04:24 PM   #3 (permalink)
There are no screws!
Thanks for responding to my message. There are no screws next to the light compartment.
What should I do?
Kathy
Old 01-17-2005, 04:40 PM   #4 (permalink)
5sp 3VZ-FE
mescalito's Avatar
hrmmm
what is there then? hah
Old 01-17-2005, 10:35 PM   #5 (permalink)
View karugs's Photo Gallery
The inner trim might be covering the screws. Your car could have the plastic velvety-cover thingie. Pull them out. If it doesn't have screws there should be a small clip that you just pry out. Don't forget to unplug the taillight assembly before you replace those bulbs. Don't also touch the glass bulbs with your bare hands--wipe them dry when you do.
karugs is offline   Reply With Quote
