Can the 3S-FE handle this? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2005, 12:33 AM   #1 (permalink)
View drugal's Photo Gallery
Can the 3S-FE handle removing the crankshaft pulley bolt by using a breaker bar and tapping the starter manually? I don't want to destroy the crankshaft or anything.
Does the pulley rotate clockwise? This would mean I'd have to place the breaker bar on the ground with the handle towards the front of the car.
1987 SV21 3S-FE
1990 SV21 3S-GTE RC
drugal is offline   Reply With Quote
Old 01-18-2005, 03:00 AM   #2 (permalink)
View 500KCamry's Photo Gallery
I did my 85 2se and 95 5sfe like that, the bolt loosens easily. A toyota mechanic told me about it. It's better to pull the all the plug wires, or the coil wire, so that it doesn't start up. It turns clockwise (when you face the flywheel) so the bar should face towards the front.
85 LE 2SE 500K km - died trying to push a semi off the road
95 LE 5SFE 530K km, 530K km changed engine, 549K km second engine died, now 554K Km running with a 98 5SFE block and head
01 XLE V6 310K km
500KCamry is offline   Reply With Quote
