Turnsignal craziness on a '99 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-19-2005, 09:38 PM   #1 (permalink)
View CHoltje's Photo Gallery
All-
I've got a 99 Camry that has developed a case of confusion...
During the day, both turnsignals flash at an even and correct rate. When the headlights power up at night, however, the left light flashes at a higher rate.
Usually this means there's a bulb or fuse out, but neither is the case.
Oh. And sometimes, it behaves normally with the headlights on.
Any ideas?
Thanks!
CHoltje is offline   Reply With Quote
Old 01-19-2005, 09:46 PM   #2 (permalink)
camry-4-ever's Avatar
View camry-4-ever's Photo Gallery
Hey! Its funny you should have this problem. I had the same problem with my 99. And I checked all the bulbs and didn't any problems. But when I talked to the guys at the shop they told me to change both turn signal bulbs in front and it fixed the problem. I haven't had that happen again since,(about 5 months ago).
camry-4-ever is offline   Reply With Quote
Old 01-19-2005, 11:58 PM   #3 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
Yeah just try changing the bulbs, and if that doesn't work try checking your wiring.
http://www.xclusive.bz
Old 01-20-2005, 09:02 AM   #4 (permalink)
Gameroom cash: $304355
If changing out the bulbs doesn't cure the problem, then try checking the socket(s) on the left side. One of the contacts for one of the dual filament bulbs might not be making a good contact.
Mike
Old 01-20-2005, 02:42 PM   #5 (permalink)
Thanks for the ideas -- I'll let you know if I have any trouble!
Thanks!
