suspension questions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-20-2005, 12:49 PM   #1 (permalink)
View Paul95's Photo Gallery
I ordered some monroe sensatrac. does anyone have them? how do you like them? I was thinking about some eibach springs as well but was told that it would loosen up my suspension becuase those struts were gas filled with a valve
anyone have any input?
Paul95 is offline   Reply With Quote
Old 01-20-2005, 01:12 PM   #2 (permalink)
camry Wookie
View gaak's Photo Gallery
are they supposed to be stock equivalent struts? cuz the theory is that if you put a stiff spring like the eibach on a stock type strut, it will cause a bouncy feeling ride because of the lack of damper in the stock strut. thats why they recomend an upgraded strut like the KYB gr2 or the Tokico HP when you go to a stiffer lower spring.
gaak is offline   Reply With Quote
Old 01-20-2005, 01:38 PM   #3 (permalink)
I'm not too sure. but I did find a little bit of info
http://www.shockwarehouse.com/cgi-bi...mon_sense.html
http://www.monroe.com/products/mp_default.asp
Old 01-20-2005, 02:10 PM   #4 (permalink)
camry Wookie
that's a tough call. IMO, i would have to place it as a high end stock equivalent. might work ok with the eibachs, but i would expect at least a slightly more bouncey ride than if you went with the KYBs or the Tokicos. however, the one thing to consider is that the higher performance struts are going to give a rougher feeling ride, while providing the handling performance that the stock struts just cant deliver.
Old 01-20-2005, 03:04 PM   #5 (permalink)
gothca, well i'm not 100% sure what i'm going to do yet. I got the rears for $107 and the fronts for $130 so i really couldn't pass it up. i have to find out where i can get stock springs from as well cuz they are worn out. I found some eibach for $230 on ebay but am not sure if they are cheaper anywhere else
Old 01-20-2005, 07:24 PM   #6 (permalink)
camry Wookie
ebay is your best bet for eibach springs, but if you are patient you can get them for like 180 plus shipping. also, if you're mechanically inclined at all, it's a real money saver to do the install yourself. i'll be willing to help you out with any questions you have, since i just did my suspension recently.
Old 01-20-2005, 08:24 PM   #7 (permalink)
The Other White Meat
terrastrife's Avatar
sensatracs arent bouncy, i have a gen3
terrastrife is offline   Reply With Quote
Old 01-20-2005, 08:34 PM   #8 (permalink)
TN's Financial Expert
BullMarket's Avatar
View BullMarket's Photo Gallery
Wow...you can get tokico blues all day for $90 each...even cheaper if you time it right on ebay.
BULLMKT
SFTIEREEL
BullMarket is offline   Reply With Quote
Old 01-21-2005, 09:45 AM   #9 (permalink)
i already have the monroe's on order and i recieved the others already. a total of $237.
wayy cheaper than $90 per strut.
I'm going to save an ass load of money and do the install myself. that is no prob at all. thankx for the offer if i need help
what kinda of springs?
