Originally Posted by tskelton1211
hey...ok i have found the site
http://www.cardomain.com/memberpage/748373/3
this site has instructions for installing the indiglo gauges on a gen 4 camry. i have them installed completely except for getting power to them. the above site says splice the hot wire into the green wire on the side of the brown connector...well...i have a green wire on both sides of the brown connector...so im unsure as how to bring power to these things...someone please help...all i have to do is splice this wire then put the bezel back on...thanks
that green wire is for the parking lights. you can use the little clip on connecter provided in the kit or I soldered mine
i tapped into the wire there because it was the same cuircut, without running it all the way to the fuse block.
but yes tap in and re assymble
