how to open camry 5th gen door ? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2005, 01:32 PM   #1 (permalink)
View butho33's Photo Gallery
im having a 2002 camry le .... i was wondering how do i remove the front door panel as i want to replace the front speakers ?plss guide ... i took out every two screws below .... one on the handle .. and another one the left ... is there any other ? i cant remove the panel still ... plss help ! urgent
butho33 is offline   Reply With Quote
Old 01-21-2005, 06:06 PM   #2 (permalink)
cam2Xrunner's Avatar
Make sure you removed all the screws and I think you have to remove the power window panel and door handl trim as well(had to remove them on my gen4)
After you have done that you need to pull the bottom of the panel to unhook it from any snap in clips that might be holding it there. You then roll down the window and pull up on the entire do panel.
There might also be an anchow screw on the sideedge of the door.
Old 01-21-2005, 06:30 PM   #3 (permalink)
View Duane Face's Photo Gallery
Lay on the ground and look up. Pull some screws. That black plastic piece up by the side mirrors. Pop them out. Pull some screws. Pop out the plastic piece behind the inside door handle. Pull some screws. When you can't see any more screws...
Lay on the ground, Part the panel from the door with a screw driver. Stick your hand in there and yank that thang out. You will hear the plastic clips poping. Don't worry, they won't break. Don't try to pull the panel all the way off though.
Reach your hand up in there and disconnect the power lock. Then proceed to lift up and pull completely off. Have fun.
Duane Face is offline   Reply With Quote
Old 01-21-2005, 07:41 PM   #4 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Now that the question has been seirously answered, someone <insert handle joke here>
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 01-21-2005, 10:42 PM   #5 (permalink)
hahah really thanks alot ....
Old 01-21-2005, 10:46 PM   #6 (permalink)
i still have a minor problem ... i cant get the door handle to pop out .... i hav yanked out the plastic holders , unscrewed all the screw and it still wont come off ? do i have to wind down the window ?
Old 01-23-2005, 11:21 AM   #7 (permalink)
Nope. You don't have to wind down the window. Look over by the door hinges. Pop off them plastic circles. There should be some screws under those too.
