carbon buildup/deposits underneath header - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2005, 12:47 AM   #1 (permalink)
poor college student
userlain's Avatar
View userlain's Photo Gallery
I've got carbon soot deposits buildup underneath my header. It is all over everything, oil filter, A/C pump, alternator, coolant lines, etc...
Any idea what this could be? I hope not a blown head gasket
'91 Camry @ ~162,900 miles
userlain is offline   Reply With Quote
Old 01-22-2005, 01:31 AM   #2 (permalink)
Where's my boomstick?
Tommy's Avatar
View Tommy's Photo Gallery
didnt you just change your header? seems pretty obvious....
you probably didnt change the gasket, so that might be leaking. or it could be like mine after my motor swap and it just took a little while for the seal to form, so it leaked for a bit. Wipe away the soot, drive it for a while, then look and see where its coming from.
My garage
1991 Nissan Maxima SE V6 5SPD - daily beater - Sold
1988 VW GTI 1.8l 16v - weekend beater - Blown engine
2005 Elantra GT sedan 5spd - Woo, no more beatup cars!
Tommy is offline   Reply With Quote
Old 01-22-2005, 01:39 AM   #3 (permalink)
userlain's Avatar
Yes I replaced the gasket(and scraped and cleaned away the old). It seems to be coming from no1 and no4 cyl exhaust ports, maybe. The bolts are torqued to 128ft/lbs.
Old 01-22-2005, 08:05 AM   #4 (permalink)
The Other White Meat
terrastrife's Avatar
lol what? you reckon you know where its coming from but dont check to make sure? the exhasut shop i went to used some gooey blue stuff for sealing
terrastrife is offline   Reply With Quote
Old 01-22-2005, 10:52 AM   #5 (permalink)
userlain's Avatar
I did it myself. And no, I don't know where it is coming from. I have an idea, but since the bolts are torqued to spec I wouldn't think its a seal problem on the header.
Old 01-22-2005, 10:54 AM   #6 (permalink)
bolts could be tight enough but there could be leakage without the correct gasket/sealant. its like torqueing up a square to a circle.
Old 01-22-2005, 10:58 AM   #7 (permalink)
userlain's Avatar
It could just be a seal forming, which is why it isn't too bad. Thanks for the input though.
