What grade of gas? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2005, 02:02 PM   #1 (permalink)
Always Under Construction
View whocares04's Photo Gallery
Question What grade of gas?
ok, i was just thinking, i have had my Camry for almost 2 years now and have only been using 89 grade fuel (b/c i have to pay for gas, insurance, repairs, etc. on own and am 18 in college ). what grade of fuel do u guys TRY to use most often and is it okay to switch grades back and forth. plus, how much of an improvement in performance, etc. should i notice, if any, by switching to like, 93 grade?
thanks guys, always a help.
-Matt
When in doubt, use the search function (link)...no one is spoon fed...
whocares04 is offline   Reply With Quote
Old 01-22-2005, 02:08 PM   #2 (permalink)
Platinum Shift Customs
Hatch's Avatar
View Hatch's Photo Gallery
You can change octains as much as you want, it will make very little difference going from 89 to 91 or 94 unless you are running higher compression and some variable valve timing.
Hatch is offline   Reply With Quote
Old 01-22-2005, 09:13 PM   #3 (permalink)
TN's Resident Car Whore!
dna59's Avatar
View dna59's Photo Gallery
I run whatever isd the cheapest at the pump. Pockets can't afford anything more.
http://www.xclusive.bz
Old 01-22-2005, 09:20 PM   #4 (permalink)
View 91MR2quickNA's Photo Gallery
The non-VVT-i 1MZ's can actually run 87 octane. The manual recommends 91 or higher for improved performance because it's equipped w/ a knock sensor. If you use 87 and don't experience knock, then use 87 for best performance and gas mileage.
The higher the octane, the more resistant it is to pre-detonation.
Jason
2005 Tacoma D-Cab 4x4 Off-Road
1991 MR2 w/ ported 1MZFE (MZW20)
1991 MR2 N/A (SW21)
91MR2quickNA is offline   Reply With Quote
