performance oil pump? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2005, 09:26 AM   #1 (permalink)
View profitwho007's Photo Gallery
Does any one know where I can get a Performance oil pump for 5sfe? And is it true that if I only replace the outside housing connected to the timing belt it will continue to leak due a possible inter oil pump gear warpage shaking that outer cover around that seal?
profitwho007 is offline   Reply With Quote
Old 01-23-2005, 10:40 AM   #2 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
View Wraith's Photo Gallery
You can convert to a 3s-gte oil pump ... Their more built for high rpm / high output
MySpace:
http://www.myspace.com/335453
Wraith is offline   Reply With Quote
Old 01-24-2005, 08:41 AM   #3 (permalink)
Gameroom cash: $147537
Will it don't have enough flow/pressure at lower RPM?
I ask cause I'm keeping the ECT Auto tranny and it doesn't rev the 5S pass 6k.
Maybe better to stick with the 5S oil pump?
I'm building NA with P&P, 11.5:1 piston and cams.
Old 01-24-2005, 09:40 AM   #4 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
the 3s-gte oil pump is still good at low rpms ... It'll flow more than the 5s pump ...
MySpace:
Old 01-24-2005, 12:34 PM   #5 (permalink)
Wintermute's Avatar
View Wintermute's Photo Gallery
http://www.importperformanceparts.ne...mpstoyota.html
They sell high volume oil pumps here.
--Wintermute
All motor. Leave the body kits off and make the car move fast, corner tight, stop fast and always blueprint your engine work.
Wintermute is offline   Reply With Quote
Old 01-24-2005, 12:53 PM   #6 (permalink)
"I BUILD SLEEPERS"
Wraith's Avatar
--Wintermute
I would not buy from them... because they have never been able to show or prove results to me, that their pumps flows more than the factory ... I've asked them plenty of times to give me some sort of grap or something to that extent and all I get is either their silence or they say that they cannot give that information out to the public...
MySpace:
