It sounds like the body shop did a good job, then they prob, switched the locks over, you might have a valet key, normally the valet key has a triangle looking top to it while the normal key is shaped more like a square on the top. Another way to test if you have a valet key is to try it in the glovebox if it dosent work there you def. have the valet key. I have never heard of being able to order new locks that match your ignition, but toyota will make you a key from your VIN number, you just need to bring the registration in and your licence, for verification. I hope this helps
