why so cold? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2005, 12:23 PM   #1 (permalink)
toyota tuner
vsixcamry's Avatar
View vsixcamry's Photo Gallery
why so cold?
after waiting about 10-15 mins. for my car to warm up i get in and its about the same temperature as when i first got in to start it. I am just wondering what i can do to help it to warm up a little quicker, the engine is warm but the car is not...
:: i heard that cardboard can be placed over the radiator to make it warm up faster.. I tryed it with my shelby dodge shadow and it worked, but the radiator fluid is nothing more than water... will this be safe for my camry??? thanks in advace guys.
vsixcamry is offline   Reply With Quote
Old 01-24-2005, 12:26 PM   #2 (permalink)
Gameroom cash: $927300
iTrader Score: 13 reviews
View ASG14's Photo Gallery
Drive it, it will wearm up a lot faster that way.
5 Lug Corolla WHAT?
Old 01-24-2005, 12:44 PM   #3 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
covering your radiator with cardboard will prolly do more damage....u are blocking its cooling abilities....and also creating a fire hazard within your engine compartment....best way to let the car heat up is to just wait....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 01-24-2005, 03:49 PM   #4 (permalink)
Pulling Out
View S2B_Blown_3.5's Photo Gallery
That, and you'd be putting a lot of strain on the electric fans on the back.
Slap me if I'm wrong
100 Posts...
-=MANUAL TRANSMISSIONS=-
Both hands on the wheel, shift with your Johnson!
S2B_Blown_3.5 is offline   Reply With Quote
Old 01-24-2005, 03:51 PM   #5 (permalink)
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
rev the engine. Even if you idle or remote start your car and leave it for 15 minutes, it won't be as warm as if you were driving the car for 15 minutes.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
Old 01-24-2005, 03:57 PM   #6 (permalink)
my name isn't really Bob
View Fresco Bob's Photo Gallery
dont leave the fan and heater on full blast either, cause then it will take longer to get hot air than if you keep the fan off till your engine is warm
Fresco Bob is offline   Reply With Quote
Old 01-24-2005, 06:47 PM   #7 (permalink)
View adroe3's Photo Gallery
turn the heater on is my suggestion
adroe3 is offline   Reply With Quote
Old 01-24-2005, 08:53 PM   #8 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
Cars are meant to be driven, not sit idling away with nothing up to tempature.
Crank it, and drive it at a normal pace. Whenever the coolant needle hits the first zone, you're at operational perameters, drive it harder (if you do drive hard).
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 01-24-2005, 09:09 PM   #9 (permalink)
View ralfp's Photo Gallery
I thought the goal was to warm up the car faster? The heater is another radiator for the car; it cools down the engine. (Where do you think the heat comes from?) That's why if you're driving in the Sahara in 120 degree weather in an old, overheating VW, you turn on the heater to cool the engine. (true story)
If you want the car to heat up faster, turn OFF the heater. Turning ON the AC might warm it up even faster (I would not recommend this for everyday use in the winter.) The fastest way, however, is to drive the damn thing. 1 minute and it's warm.
ralfp is offline   Reply With Quote
Old 01-25-2005, 02:30 PM   #10 (permalink)
Pulling Out
Very true, same applies to driving in 4WDL on the beaches of NC, 3 hours straight at 25 MPH, heater cools engine down. Also a true story.
Best advice is to drive normal, higher rpms will increase engine temps faster.
Old 01-25-2005, 03:06 PM   #11 (permalink)
View anuthaCamry's Photo Gallery
turning on the ac will not warm up the car faster because it also activates the cooling fan. turning on the heater will hopefully warm up the car, but to add more load you can turn on the high beams. It doesn't freeze over here, but if it did maybe I would cover part of the radiator like you see those yukon truckers do on tv.
anuthaCamry is offline   Reply With Quote
Old 01-25-2005, 05:35 PM   #12 (permalink)
View grizzlyadams73's Photo Gallery
our 95 is like that. i noticed if you have it on defrost you get very little heat. change it to the vent and floor and it will cook you out.
grizzlyadams73 is offline   Reply With Quote
Old 01-25-2005, 06:23 PM   #13 (permalink)
I forgot about the AC turning on the cooling fan. BUT: Does the radiator coolant flow when the engine is cold? If not, the cooling fan shouldn't matter much.
Old 01-25-2005, 08:28 PM   #14 (permalink)
97 Camry
View Davee's Photo Gallery
In the north we use cardboard all the time. Does not do much for warm up time but keeps coolant warm for longer after shutdown. Check to be sure that no warm hose to the rad can be felt until gauge gets moving up . If it warms right away (1 minute or so) you have a bad thermostat. You could also fit a block heater (110 volt plug in) . we use these for a couple of hours on a timer before driving
PS I left cardboard covering 1/2 thre rad all last summer (mistake) . It still did not overheat or otherwise screw up. It might have cost me some A/C performance
Davee is offline   Reply With Quote
