Lowered Camry = Adjust Headlights? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2005, 12:29 PM   #1 (permalink)
View 604-Mico's Photo Gallery
For all you Camry owners who have dropped their car...
Did you guys adjust your headlamps to point upwards a bit?
Cause after driving for a good 5 months with a lowered car, i finally realized i cant see shit at night even with my headlights on
'94 1mzfe Coupe
2.5" dropzones
Tokico Blues
Gen 3 Camry SE wheels
APS-996 Alarm-Starter Combo
604-Mico is offline   Reply With Quote
Old 01-24-2005, 12:43 PM   #2 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
It is not an issue with the drop it is something else. A 1.5 inch drop is nothing. Mine is down like 1.8 and I have no issues.
97camryman is offline   Reply With Quote
Old 01-24-2005, 12:54 PM   #3 (permalink)
There's a post button?
View Yanahdi's Photo Gallery
Easiest solution IMO is just go out and get some Sylvania Silverstars.
Replacement headlight with much better visibility and it plugs in just like an OEM bulb.
You just have to make sure you know your bulb number when buying them.
1999 Solara SE (5S-FE)
Eibach Springs
Bilstein Struts
Whiteline Swaybars (Front and Rear)
TRD Quick Shifter
A'pexi World Sport Cat-back exhaust
Ripp Mods Header
K&N Air Filter
RESISTANCE IS FUTILE
if < 1 ohm
Yanahdi is offline   Reply With Quote
Old 01-24-2005, 04:49 PM   #4 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
9006 lowbeam 9005 highbeam
WhiteRabbit is offline   Reply With Quote
Old 01-24-2005, 04:55 PM   #5 (permalink)
Rotor > Piston
powderblue91's Avatar
View powderblue91's Photo Gallery
you *should* have to adjust them considering they are not in the same position.
-Eric
1991 SV21 DX - The slow
1990 FC3S GXL - The go
powderblue91 is offline   Reply With Quote
Old 01-24-2005, 04:56 PM   #6 (permalink)
View ralfp's Photo Gallery
If you lowered the front more than the rear (even slightly), your beams would be pointing down. That would make a lot more difference than any height difference.
ralfp is offline   Reply With Quote
Old 01-24-2005, 06:25 PM   #7 (permalink)
slowamatic noob
a94autoCamry's Avatar
Gameroom cash: $149910
View a94autoCamry's Photo Gallery
yep, i had to adjust my headlights after i lowered the car, my front is lower than the rear...but i got some silverstars 9005's on all four and the light output is way better than stock
slow white - "no show and no go"
a94autoCamry is offline   Reply With Quote
Old 01-24-2005, 07:15 PM   #8 (permalink)
amerikim's Avatar
View amerikim's Photo Gallery
All the lowering springs I looked at lowered the front more than rear.
I installed H&Rs and high speed runs at night in the country were scary. I couldnt see anything in turns. So I readjusted it myself. Still feel it's off and will bring it in eventually to get that taken care of. I was extra careful to make sure they were not too high, courtesy counts. Don't know if I will do the mod to put high beams (9005) in my low beam sockets (fitted for 9006), some people like it but so far I think it's pretty decent.
amerikim is offline   Reply With Quote
Old 01-24-2005, 07:16 PM   #9 (permalink)
gLok's Avatar
View gLok's Photo Gallery
I had to adjust mine as well. I simply aimed the car at a wall and adjusted them until i was happy.
gLok is offline   Reply With Quote
Old 01-24-2005, 07:20 PM   #10 (permalink)
3rd 5-speed Camry...
87Camry5Speed's Avatar
View 87Camry5Speed's Photo Gallery
WhiteR 9006 lowbeam 9005 highbeam
If you're handy, you're just a Dremel away from 9005 highbeams AND lowbeams
Steve
'08 Camry LE 5-speed. Traded for an '04 Mustang GT.
87Camry5Speed is offline   Reply With Quote
Old 01-25-2005, 02:26 AM   #11 (permalink)
I have a 2.5 drop
And yea i think i really should install my silverstars one of these days...
'94 1mzfe Coupe
2.5" dropzones
Tokico Blues
