hot hot heat (not!) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2005, 09:53 PM   #1 (permalink)
5sp 3VZ-FE
mescalito's Avatar
View mescalito's Photo Gallery
Arrow hot hot heat (not!)
soooo
when i need some heat, i crank the dial to give me appropriate strengths of air...seems simple enough, right? well it only works on the 2nd half of the dial ie the high flow side - the bottom half doesnt blow shit and you can't hear the fan running
i know this was an issue with gen 2's and all you had to do was replace a teeny bit - is it the same for gen 3's too? anyone else have a similar problem?
if in fact there is also a thread that addresses this problem, now is your chance
mescalito is offline   Reply With Quote
Old 01-25-2005, 01:05 AM   #2 (permalink)
Platinum Shift Customs
Hatch's Avatar
View Hatch's Photo Gallery
I would attribute the problem to either a faulty switch or fan (duh ) but hoenstly i would be inclined to pull the switch first and then pull the fan. Hopefully you can narrow it down this way.
Hatch is offline   Reply With Quote
Old 01-25-2005, 08:56 AM   #3 (permalink)
5sp 3VZ-FE
mescalito's Avatar
are they two-stage fans?
Old 01-25-2005, 09:21 AM   #4 (permalink)
Hatch's Avatar
Well usually its a multi speed fan, the speeds depends on the current being sent to it.
Old 01-25-2005, 09:24 AM   #5 (permalink)
5sp 3VZ-FE
mescalito's Avatar
so maybe it's a fuse then?
Old 01-25-2005, 02:45 PM   #6 (permalink)
Auto-Cross Addict
SmokingTires's Avatar
View SmokingTires's Photo Gallery
More likely if a fuse was to blow, it would effect the high end rather than the low end. Because the high end would recieve the strongest current, thus blowing the fuse.
Do all fans die at low speeds? Even the ones under the dash?
'88 Toyota MR2 N/A - Sold
'99 Miata Sport - Sold
'85 Corolla GT-S - Sold
'02 MR2 Spyder - C-Stock car
SmokingTires is offline   Reply With Quote
Old 01-25-2005, 02:56 PM   #7 (permalink)
View anuthaCamry's Photo Gallery
this happens to japanese cars, it's not uncommon, happened to all my other jap cars
it is likely the blower resistor
anuthaCamry is offline   Reply With Quote
Old 01-25-2005, 07:02 PM   #8 (permalink)
5sp 3VZ-FE
mescalito's Avatar
ah ha! no we're on to something boys!
tell us more about this 'blower resistor'
Old 01-25-2005, 07:20 PM   #9 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
^ Heres a link to a thread I started recently.
http://www.toyotanation.com/forum/t62289.html
"Skoolin' the unlearned!"
Old 01-25-2005, 07:27 PM   #10 (permalink)
5sp 3VZ-FE
mescalito's Avatar
yesssssss
many thanks 88 LE
Old 01-25-2005, 08:17 PM   #11 (permalink)
97 Camry
View Davee's Photo Gallery
You don't "send" current ! Any electrical device decides on it's current based on its resistance & the applied voltage.
Davee is offline   Reply With Quote
Old 01-25-2005, 08:26 PM   #12 (permalink)
View toysarefun's Photo Gallery
You mean amps?
http://www.kpsec.freeuk.com/ohmslaw.htm
toysarefun is offline   Reply With Quote
Old 01-25-2005, 11:13 PM   #13 (permalink)
Hatch's Avatar
thanks for another usless post Davee, im sure he knows what I meant.
