Can't shift from Park (automatic)!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2005, 10:40 PM   #1 (permalink)
Always Under Construction
View whocares04's Photo Gallery
Question Can't shift from Park (automatic)!!!!
ok so the other day i started my car like normal and tried to take it out of park and the shift button was locked. so i overrode the shifter with that "shift override" and created a way so that the button is always overrode b/c it still won't shift from P. it shifts from every other gear except FROM park...driving it shifts perfectly.
any ideas, suggestions, etc???
thanks you guys for always help....
-Matt
When in doubt, use the search function (link)...no one is spoon fed...
whocares04 is offline   Reply With Quote
Old 01-24-2005, 10:44 PM   #2 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $112750
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
the sensor or switch at the brake petal might be stuck or broke... check the carpet around the switch, I had the same problem in my wife's car with the carpet around the brake light switch.
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is online now   Reply With Quote
Old 01-24-2005, 10:48 PM   #3 (permalink)
Motorcyle Tech
Racer_Rodney's Avatar
View Racer_Rodney's Photo Gallery
yeah and check the fuses to it, mine does it once in a while. does anyone know what is the cause?
the shop told me like $75 an hour to "chase it down"....pfffft whatever you can chase my balls for $75 an hour
CarDomain pics-->http://members.cardomain.com/racer_rodney
My WebSite------>http://rcarman.home.mchsi.com/
Racer_Rodney is offline   Reply With Quote
Old 01-24-2005, 11:07 PM   #4 (permalink)
View anuthaCamry's Photo Gallery
I have the ultimate solution to this problem.
At some point your car, like mine, had liquid spilt into the shifter. When this liquid got cold after a good nights rest for your car, and you - it became sticky and viscous preventing the actuating electromagnet from working right.
This requires removing shifter cover, the center console (armrest), and the console body around the shifter. I'm not sure of whether or not the shifter needs to be removed to get to that part, but simply cleaning the sticky stuff should suffice.
BUT SIMPLY REPAIRING IT IS NOT GOOD ENOUGH FOR ME
I don't want to be stuck in park while freddy kruger moseys on up to my window, I wanna be able to shift when I want to. So here's what I did:
After I got everything cleaned up and to full stock working condition, I wrapped several large cable ties around the overide - secondary lever. Now it operates as if the override button were always pressed in.
It funtions exactly the same way cars in the 80s worked before someone invented the brake pedal & shift out of park interlock. (damn those audi 5000s!!!)
anuthaCamry is offline   Reply With Quote
Old 01-25-2005, 12:09 AM   #5 (permalink)
97camryman's Avatar
View 97camryman's Photo Gallery
I have a manual shift knob on mine holding down the rod. I made a shift boot for it and a lexan trim piece. No more brake override or anything. The car goes into any gear you want any time so be careful. It is an interesting mod cause everyone assumes its a manual at first and then you tell them its not and they are like wow......wait how does that work?
Check out the picture:
http://memimage.cardomain.net/member...928_5_full.jpg
97camryman is offline   Reply With Quote
Old 01-25-2005, 01:25 AM   #6 (permalink)
you still have to push in on the shift button on my mod, it's behaves like any stock car made until 1991 or so when the interlock was mandated. you still need to have the tran in P to remove the key. It is my opinion that the brake-shift out of park interlock is a detriment and an annoyance of no value. It was probably due to an alleged fault of the audi 4000s that prompted such a device.
Old 01-25-2005, 12:41 PM   #7 (permalink)
thanks guys for all the help!!!
i'll first try the simple things then do anuthacamry's suggestion.
but as far as you guys know it's not a huge problem like tranny, right?
thanks again!
-Matt
Old 01-28-2005, 12:05 AM   #8 (permalink)
View tardis24's Photo Gallery
If the brake pedal switch is not working, you may find that your brake lights don't work either. Please check that also.
tardis24 is offline   Reply With Quote
Old 01-28-2005, 05:54 PM   #9 (permalink)
View mcelligott's Photo Gallery
Do you have an aftermarket shift knob? If you do, take it off and it will shift out of park again.
Turbo 3vz-fe with Nitrous...you have questions? I have answers, Get a hold of me on aim!
mcelligott is offline   Reply With Quote
Old 01-28-2005, 06:18 PM   #10 (permalink)
VeeZed
JetspeedCamry's Avatar
View JetspeedCamry's Photo Gallery
Any chance of someone explaining this 'shift interlock'?? I've never driven a car with oine..so what is it?
1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
JetspeedCamry is offline   Reply With Quote
Old 01-28-2005, 10:54 PM   #11 (permalink)
get into your 1992 or newer, unaltered, US market, automatic transmission passenger car.
push in on the shift button and shift from P into any gear.
did you have your foot on the brake?
try that again without touching the brake pedal, did it shift? or was is stuck?
the brake pedal-shift out of park interlock is that 'glue'
(now try taking the key out the ignition with the car in drive...)
