Question about the MPG after replacing the TB - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-26-2005, 12:33 AM   #1 (permalink)
View stanleyeye's Photo Gallery
Unhappy Question about the MPG after replacing the TB
About two months ago, I replaced the timing belt by myself. Now, I find the MPG is much lower than before. Someone told me that I needed to adjust the distributor. My car is 98 camry, and I am pretty sure there is no distributor. So I am wondering what causes this problem. By the way, if I haven't adjust the timing pretty well, will it affect the acceleration?
many thanks
stanleyeye is offline   Reply With Quote
Old 01-26-2005, 12:35 AM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
if youre timing is off yes it will effect mpg and acceleration etc la di da... :P err thats all i can really explain
terrastrife is offline   Reply With Quote
Old 01-26-2005, 12:44 AM   #3 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
do you have a v6 or i4? that'll help a lot.
if it's a v6, you're right, you can't adjust the timing (it's uses DIS)
if your car is an i4, you can adjust timing.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 01-26-2005, 01:19 PM   #4 (permalink)
Toysrme's Avatar
View Toysrme's Photo Gallery
Cool
I say he got the cam timing incorrect.
AIM/Yahoo Toysrme257th
Now with Turbo!
Old 01-26-2005, 01:27 PM   #5 (permalink)
View anuthaCamry's Photo Gallery
ditto
anuthaCamry is offline   Reply With Quote
Old 01-26-2005, 08:04 PM   #6 (permalink)
There's a post button?
View Yanahdi's Photo Gallery
Incorrect timing due to a worn belt or just incorrect calibration can indeed affect acceleration and a number of other factors.
Hell I had the TB replaced on my Solara at about 70k I think and the engine note was a lot different in the high RPM band, as well as a slightly different power curve.
1999 Solara SE (5S-FE)
Eibach Springs
Bilstein Struts
Whiteline Swaybars (Front and Rear)
TRD Quick Shifter
A'pexi World Sport Cat-back exhaust
Ripp Mods Header
K&N Air Filter
RESISTANCE IS FUTILE
if < 1 ohm
Yanahdi is offline   Reply With Quote
Old 01-27-2005, 09:41 PM   #7 (permalink)
I have a I4, could you tell me how to adjust timing. I think I installed the tb correctly, because I did just what the toyota manual said. And I found a really strange thing, the new tb is a little longer that the old one. Could it cause this problem?
Old 01-27-2005, 09:49 PM   #8 (permalink)
hmm, the slack in the belt could be allowing the timing to slip a little bit over time.
perhaps something wasnt tightened properly?
I have no idea why it would be longer than the original.
Eibach Springs
Bilstein Struts
TRD Quick Shifter
Ripp Mods Header
K&N Air Filter
if < 1 ohm
Old 01-27-2005, 10:08 PM   #9 (permalink)
Maybe, after some time, the belt will become shorter.
