Need help or opinion on cone filter installation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-26-2005, 09:14 PM   #1 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
Unhappy Need help or opinion on cone filter installation
hey im a newbie and have a few ?'s regarding a 1993 camry with 3vz eng.
how would i install an aftermarket cone filter?
what is your best recommendation?
thanks!
BlueFusion6851 is offline   Reply With Quote
Old 01-26-2005, 10:15 PM   #2 (permalink)
The Other White Meat
terrastrife's Avatar
best reccomendation: dont touch it.
read the faq, theres and air box mod guide there.
if you want a proper ram/cold air intake, make it yourself, you know, bend metal, move bits, etc.
terrastrife is offline   Reply With Quote
Old 01-26-2005, 11:25 PM   #3 (permalink)
Banning is an art.
Silver Streak's Avatar
View Silver Streak's Photo Gallery
There are a TON of threads here in the Camry section regarding cone filters...like probably at least a couple of hundred. Definitely start searching and reading! As well, check out my Camry website, there's some pics of filters on there, as well as the first homemade (that I knew of) cold air intake (CAI). (*edit -for the 3VZ in a Camry in Canada. *)
Good luck!
Silver Streak is offline   Reply With Quote
Old 01-27-2005, 08:42 PM   #4 (permalink)
How hard can it be?
ok will do thanks for the help
sean
