Ebay for the manual (you could probably get by with a 1992,93, or 94 manual, and even a 95/96, but there might be very slight differences with those two years... mainly with how to change the front turn signal bulbs and stuff), and there are many cheap reliable sources for spoilers, depending on what kind you want.... authentic OEM or aftermarket, or OEM "style"?... Try searching this forum to find some info. Keep in mind that if you install a spoiler that has a brake light in it- you might run into problem if your car has a rear light failure sensor... (you'll know if when you start your car, a small orange light on the dash comes on for a second-that pictures a car.) (I'm not sure if 1992s had one, but I know more recent Camrys do.
As for the sunroof- I would really think twice about adding an aftermarket sunroof. They usually leak after a while. There was a recent thread on sunroofs as well...instead of me repeating it all, try searching for that too.
Good Luck, and congrads on your Camry purchase! Welcome to our family.
2007 Camry Hybrid
