Originally Posted by casenickles
Is it possible to take the 2.0 L out and drop in the 2.5 L 6 cyl. Also where can I find lots of information on the 1991 model, like prices on parts and such. I have around 2-3 K to put into it right away.
Its possible, but the 2.5L (2VZ-FE) will not mount in place of your 2.0L (3S-FE). The left side engine mount is different.
If you get it to mount up (use a custom mount) you still have to deal with the wiring.
You can buy a low milage JDM 3S-FE for $200 - $225. Its a drop in replacement for your current engine.
For struts you have 2 choices. KYB GR-2 and Tokicos. However the Tokicos are cartridges, so they'll only work if you have serviceable struts.
Lowering springs: Intrax
Front and rear swaybar: Whiteline
Front strut tower bar: Look on eBay. IIRC a guy named meganracing sells them.
