I juset installed a crimestopper keyless entry system in my 94 le and i cant get the parking lights to flash with the lock/unlock. I have searched and found many different locations to tap into to get them to flash. No matter where i tap only the headlight low beams will flash. Even when i tap straight into the driver parking light only the headlight will flash. Anyone that can tell me where they tapped to get the parking lights to flash?? I would leave it like it is but im afraid of the current draw on battery for headlights to flash. Thanks..
Probably something to do with the Toyota auto lights off function. What about the brake lights circuit ? Simply add a relay driven by the alarms flash output with the switch contacts across the brake switch connections.
Do you have the wiring info that was on here for the 94 Camry ? It appears you will be looking for the green wire. Not sure why the headlights would flash. If you don't have the wiring PM with E-Mail address and I will scan them.
Is your lead for flash from alarm providing voltage ? or providing ground ?
Thats where i have the parking light flash output from alarm. I also have the dome light wired to the red/white wire in the same connector. I also tried the suggestion for wiring it to the rear brake lights/ parking lights but still the headlights only flashed.
Once again you guys have helped me out of a jam. I unhooked everything and rewired the power and ground and light output and it works great now. Couldnt have done it without the wiring diagrams. Thanks
The best thing i did was search all the camry forum for alarm and wiring and get as many different wire color diagrams as you can get. After searching i found 4 wiring color diagrams that all were different in some way on different wires and thier locations on the car. Use a multimeter to find which wire color/location works for you.... If you want to know specifically which ones i used let me know what you are hooking up........
