best cold air intake - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2005, 10:48 PM   #1 (permalink)
View suprakid95's Photo Gallery
Hi my friend wanted to mod his car up a little bit and asked me if I could find a good cold air intake for him. So I searched around and did'nt find much for the 1991 3sfe motor that he has. Can u guys give me a few links as to where I can find him a decent intake for a decent price?
Thanks
-S
suprakid95 is offline   Reply With Quote
Old 01-30-2005, 10:58 PM   #2 (permalink)
Always Under Construction
View whocares04's Photo Gallery
(correct me if i'm wrong but you guys would neways... )
i believe the ONLY CAI is from you....has to be custom made
there's alot of ppl who have done this...they should be able to help you out.
-Matt
When in doubt, use the search function (link)...no one is spoon fed...
whocares04 is offline   Reply With Quote
Old 01-30-2005, 11:40 PM   #3 (permalink)
Gen 2 Pimp
phat91camryLE's Avatar
View phat91camryLE's Photo Gallery
el prototypes has one...its 160 bucks...i have one
later
Matt
4 cyl 1991 Camry LE ... if you own a 2nd Gen Camry talk to me about the modifications you have made or wish to make... lets help eachother out
phat91camryLE is offline   Reply With Quote
Old 01-31-2005, 09:58 AM   #4 (permalink)
toyota tuner
vsixcamry's Avatar
View vsixcamry's Photo Gallery
i have short rams, but no CAI's. CAI's all all custom.
vsixcamry is offline   Reply With Quote
Old 02-01-2005, 12:43 PM   #5 (permalink)
I work on euros.
View 96CamrySport's Photo Gallery
I was told that most camrys have no real intake restriction; head work is much more useful. Sounds like that's kinda out of your range tho. Next best move is K&N filter, and I just put some dryer ducting up to the stock airbox. Does much better than the rest of the system (stock exhaust, blech)
96CamrySport is offline   Reply With Quote
Old 02-01-2005, 12:51 PM   #6 (permalink)
Zzzz
CrawlingEye's Avatar
View CrawlingEye's Photo Gallery
El Proto makes a CAI for it (elprototypes.com) and you can also make one yourself, which is the route I'd take.
-mark
'93 Camry LE (5S-FE)
CrawlingEye is offline   Reply With Quote
Old 02-01-2005, 01:25 PM   #7 (permalink)
View anuthaCamry's Photo Gallery
post a picture of this notorious CAI
anuthaCamry is offline   Reply With Quote
Old 02-01-2005, 02:42 PM   #8 (permalink)
Pulling Out
View S2B_Blown_3.5's Photo Gallery
I do believe this is it
-=MANUAL TRANSMISSIONS=-
Both hands on the wheel, shift with your Johnson!
S2B_Blown_3.5 is offline   Reply With Quote
Old 02-01-2005, 02:45 PM   #9 (permalink)
Gameroom cash: $147537
DYI is best. Cone filter of your choice and a few pipes with bends.
A K&N drop-in filter make good stock CAI.
Old 02-01-2005, 02:46 PM   #10 (permalink)
where does it get its cold air? from the left front fender like stock? pic of one installed?
Old 02-01-2005, 02:55 PM   #11 (permalink)
Stock is cold air. The stock air box get air from behind head light. There is a resonator box behind fender. Remove it and it may sound louder. Usually remove battery and you can see all the piping.
Old 02-01-2005, 02:57 PM   #12 (permalink)
the intake air muffler, or anti-rice box
why not remove that in the first place and spare the expense of all the shinys
Old 02-01-2005, 04:32 PM   #13 (permalink)
Zzzz
yup and right along side the radiator. I don't know why none of you like to admit it, but the stock location isn't ideal by a long-shot.
-mark
Old 02-02-2005, 05:20 PM   #14 (permalink)
I work on euros.
We like this because all you have to replace is a big, heavy resonator with a little bit of piping, you can keep the stock airbox (probably), and there is metal between the radiator and the cold, cold air that can be found right behind the driver's side brake duct. It'd probably be a lot better if it scavenged air from under the windshield wiper cowl, but I think rain'd be a problem. My only problem with this system is, after you idle at a stoplight, that fat black airbox gets pretty hot, but it cools down quickly once you get air flowing thru again.
1996 Camry Sport (that's a DX Coupe with decals) with 186k
european cars are just like japanese cars, just heavier and more expensive.
7 ASE's.
Old 02-02-2005, 05:54 PM   #15 (permalink)
Zzzz
I've already tried the plugged resonator mod, which netted very little gains on the bottom-end.
Similarly, the throttle response seemed to have suffered.
-mark
