I have noticed the under full acceleration (pedal to the floor!) the car doesnt accelerate as quickly as it does when the pedal is 90% to the floor.
I notice this on a nice cool night, where the car would be running really well.
Onto a straight..foot down the pedal 80%....then 90$ (pulls sooo good) and then flat to floor...seemed like it lost a bit of acceleration.
It's not like a surging or momentary thing..its all the time. If i hold the pedal at about 90%...the car keeps accelerating great!
What could be causing this problem?
I was under the impression that full power is obtained with the pedal to the floor, unless its not tuned properly. This happens, not just with my airbox installed, but with my open POD filter aswell.
Any ideas?
__________________ 1988 Toyota Camry 2VZ-FE E153
1972 Ford Mustang Sprint "F" 351C-2V 4SPD
1973 Ford Mustang Mach 1 "Q" 383C-4V FMX
all the cars ive driven have done this aswell
my old Gen3, my Gen5.5 and my dad's Kluger.....
if i mash the pedal it will not accelerate as well as 90% like you said...
i have a feeling it has something to do with the automatic transmissions...
i guess they are like that
i honestly havnt noticed this problem with my auto. I'll put my foot down 90% and see what happens. i've noticed your problem in my girlfriends lancer (eeeeewwww). its an auto 2. i just feel i wouldnt be doing it right if i didnt have my foot to the floor.
Well..for as long as the auto is in there, why not just adjust the throttle so it only opens to 90%! Then you'll get full torque converter lockup everytime you floor it.
how would u noe to put it at 90% cause im clueless about this. i did adjust throttle cable somewhat but not sure wat exactly its at. my car does the same all u hear is the big engine roaring nd thats it.
I have been given a sickness from the doc... Obsessive Compulsive Camry Dissorder... certifiable
Adjustment or Driving?
For adjustment, just look at the throttle assembly (the part the pivots and opens the butterfly in your TB) and adjust it so that when you depress the pedal fully, the assembly still has a little bit to go.
Otherwise for driving, i would just floor it, and then lift your foot off slightly.
Damn these 2VZ's sound good tho with an open filter!!! Roooaarr.
Put a mark on the throttle cable/assembly (the part that rotates)
Get a protractor and center it on the center peg of the assembly
have someone press the pedal to the floor and see what angle the mark moved.
Multiply that by 0.9 or 90%
Reset the assembly so that, when the pedal is on the floor, the mark comes to this angle.
I personally will leave mine alone, because when this is done it prevents you from running WOT if you wanna go top speed. You can only get 90% throttle.
-=MANUAL TRANSMISSIONS=-
Both hands on the wheel, shift with your Johnson!
Yeah that works!
Dont really do WOT throttle pulls around here! Theres too much cop presence!
But yeah..perhaps the best thing to do is just manipiulate the pedal a bit when accelerating..that way u still have the option of going WOT.
Oh wow boys...The transmission scales with rpm... It doesn't matter if the engine is running @ 50%, or if it's running at 100%. More power = more acceleration <period>.
Look for an actual engine problem.
Take the hose to the airbox off and flip the throttle open. Look down the throttle body and see how far the plate is opening. If it opens fine the good.
May have some very slight fuel problem also, so check the related system for that too. You know the drill
"The lamest twice banned, non-female member of-all time." -Ekam, Thanks, I <3 you too! AIM/Yahoo Toysrme257th
for anything, anytime; including camry turbos Now with Turbo!
just wondering how do i get rid of stiff gas peddle because it gets real stiff when im driving around. i did check throttle body nd its clean. any other things i need to look at?
